Go Back   DodgeForum.com > Dodge Cars > Dodge Avenger > 1995-2000 Dodge Avenger
Sign in using an external account
Register Forgot Password?
1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
Thread Tools Search this Thread
Old 02-23-2008, 04:47 PM
born4baseball born4baseball is offline
Garage is empty, add now
Default 96 Avenger 2.5...will not turn over
My 96 began to have electrical problems like the blinkers not working propeperly, the curise control not working, etc. Then one day the car decided to die, after much diagnosis, we got the car to finally crank by replacing the Starter. The car really wanted to start but it wouldn't turn over. At this point we smelled gas and pulled the plugs out and they were soaked in gasoline. We replaced the plugs and tested the wires. The car has spark as well. We soon took it to a dealership and they realized that the fuel injector was not seated propperly. We reseated and tested all the fuel injectors with an Oms meter, they were all good. My father seems to think that when we took off the intake manifold and replaced the vaccume lines, we hooked them up wrong, or there is a leak in the vac lines. I am like 95% certian they are all hooked up correctly. I think it might have something to do with the PCM/ECM computer and I don't know whats wrong. We are at a standstill because everything in chilton tells us to test the car with it running, and we can't get it to start in the first place. Anyone with some insite, I'd appreciate it, thanks.
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on Dodge Forums!
__________________
Mike
Old 02-23-2008, 07:45 PM
bad venge's Avatar
bad venge bad venge is offline
Section Moderator
Dodge Forum Moderator
1998 Dodge Avenger
Vehicle: 98 Dodge Avenger
Default RE: 96 Avenger 2.5...will not turn over
same as on ASEC ... Check the relays and the CPS ... Test procedures above in the stickies
Old 05-14-2008, 02:22 PM
Default RE: 96 Avenger 2.5...will not turn over **update**
just wanted to give everyone an update...i've finally got the car running...apparently somehow the timing slipped, which makes no sence because i have a zero-interference engine, so who knows....but low and behold i started the engine the other day and put everything back together...The only problem is that 1) I have white smoke coming from the exhaust pipes, and 2) the idle is low...oh yeah...i still have all the electrical problems.....
I've looked up the white smoke, so far what i hear is that the smoke can be caused either by a blown head gasket or a cracked cylinder head, or because some coolent has gotten somehwere it shouldn't be...i've filled up the radiator, and the overflow resivour, and let it run, but it continues to put out white smoke (only when it is warmed up)....as for the low idle, i have had this problem before, and i can't remember what fixed it, however, i've seen it a million times on the forum, so i will look on another thread....the electrical problems still persist, i don't even want to think about those till the engine is working right.....and oh yeah, the back rotors either need to be turned or replaced.....so thats were we stand...thank all of you for all the help and advice so far..
MIKE[/align]
__________________
Mike
Old 05-14-2008, 08:47 PM
bad venge's Avatar
Section Moderator
1998 Dodge Avenger
Are you POSITIVE there was no damage from the timing jump ??? My guess is there was damage that might have cracked the head
Low idle , have you seafoamed the intake ???
Old 05-18-2008, 12:46 AM
yeah, it was just the car burning off a lot of oil from the engine heating up...i guess i shoulda mentioned that the smoke wasn't coming from the tailpipe, n was from the block area....its fine now, i'm just working on getting this electrical problem solved, i think its got to do with the turning signal flasher relay swtich box....man diagnosing electrical problems is a nightmare
__________________
Mike
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
Vendor Directory
Our Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.2
Contact Details & Emails
