DodgeForum.com
DodgeForum.com Home - Dodge Marketplace - Dodge Photo Galleries - Create an Account - Dodge News
Go Back   DodgeForum.com > Dodge Cars > Dodge Avenger > 1995-2000 Dodge Avenger
Thread Tools Search this Thread
Old 07-30-2008, 01:10 PM
invsbl1 invsbl1 is offline
Default 98 AVENGER FAULT CODES, TCC CIRCUIT
I HAVE A 98 AVENGER WITH 71000 MILES 2.5 V-6 AUTO TRANS, THE CHECK ENGINE LIGHT CAME ON, AUTOZONE READ CODES (TRANS FAULT 700) AND (TCC CIRCUIT, I THINK 740, 743, OR 734), BUT I KNOW IT SAID TCC CIRCUIT FAULT. TOOK IT TO THE CHRYSLER GARAGE, THEY CHECKED CODES, COULDN'T FIND ANYTHING WRONG, CLEARED COMPUTER, LIGHT CAME BACK ON TWO DAYS LATER, SAME CODE. DOES ANYONE HAVE A CLUE WHAT COULD BE THE PROBLEM? THE CAR RUNS FINE, NO TRANS PROBLEMSOUT ON THE ROAD. I NEEDS TO BE INSPECTED BY THE END OF AUGUST, IT WON'T PASS WITH THE CHECK ENGINE LIGHT ON. THIS IS A GREAT CAR, PLEASE HELP!!!!!!!!!!!!!!!!!!!!!!!!!!!
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on Dodge Forums!
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
Old 07-30-2008, 03:12 PM
bad venge's Avatar
bad venge bad venge is offline
Section Moderator
Dodge Forum Moderator
1998 Dodge Avenger
Vehicle: 98 Dodge Avenger
Default RE: 98 AVENGER FAULT CODES, TCC CIRCUIT
True Dodge codes are 2 digits 11/71 ... The three digits you give I can not cross to ... From a quick look I see NO TCC codes ... Sure they are not TPS ???
Old 08-01-2008, 12:32 PM
THE CODE CAME ACROSS PO700 AND PO734 TCC CIRCUIT, THIS IS ACCORDING TO AUTOZONE AND CHRYSLER/JEEP DEALER. THE SHOP FOREMAN SAID IT COULD BE THE TORQUE SOLENOID PACK OR THE TORQUE CONVERTOR ITSELF. THE CAR DRIVES JUST FINE, ANYBOBY ELSE WITH THIS PROBLEM?? CHECK ENGINE GOES OUT ONCE CLEARED, COMES BACK ON THREE DAYS LATER.
Old 08-05-2008, 12:30 AM
master tech master tech is offline
Vehicle: Mits P/U , Dodge avenger(1996) .
Send a message via Yahoo to master tech
P0740 is a torque converter control code and could be an internal problem, and P734 is gear ratio error in 4th gear. If you would like PDF file for your codes, just send a pm.
__________________
Master Chassis tech, Transmission
Automatic and Manual and Suspensions.
Also repair front and rear diffs and all engine
repairs inc Diesel. A/C repair too.
Old 08-14-2008, 01:02 PM
Sorry it took so long to get back to you, on vacation all last week. Dealership said it could be the torque converter going bad, but it doesn't act like it is, it shifts fine. They also said it could be the input and output speed sensors or solenoid pack. I don't want to just chase parts, can you buy the solenoid pack from someone?? Autozone, advanced auto parts?? Etc... I can buy the speed sensors, about $30.00 for the pair. Could it be anything else??? Like i said, it doesn't have any shifting problems, very smooth, no noise!!! Thank you for your help
Old 08-14-2008, 01:23 PM
bad venge's Avatar
Section Moderator
1998 Dodge Avenger
If it's the output speed sensor the speedometer dies ... You never stated that ...
Tags
1995, ads, avenger, chrysler, circuit, code, codes, diagnostic, dodge, pack, po740, selenoid, solenoid, tcc, torque, trouble
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
