DodgeForum.com
DodgeForum.com Home - Dodge Marketplace - Dodge Photo Galleries - Create an Account - Dodge News
Go Back   DodgeForum.com > Dodge Cars > Dodge Avenger > 1995-2000 Dodge Avenger
Thread Tools Search this Thread
Old 05-12-2009, 12:12 AM
rudegirl rudegirl is offline
Default 1995 Avenger still having issues
Well i took my avenger to the shop and they seem to think its the transmission Still drivable for now so will have to save for that fix. My current problem is it won't start. Won't even turn over .When i turn the key the dash lights come on but doesn't crank. I hear a click from under the hood. The guy that had this car before me wired up lights under the dash and seems to have made a mess of them. could this be the problem? The wires in the steering column have be tampered with as well. There is wires in the column that lead to under the hood and are not attached to anything.. had it towed home the first time it happened and it started the next morning and now has done it again after a week of no problems . Any suggestions to what this could be? any help would be greatly appreciated.
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on Dodge Forums!
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
Old 05-12-2009, 01:39 PM
Killa200 Killa200 is offline
Vehicle: 1997 Dodge Avenger ES
Send a message via AIM to Killa200 Send a message via Yahoo to Killa200
Sounds like an aftermarket anti theft was installed at one point if there is extra wire leading from the column. Pull the battery and try tracing down all the unused wiring you are suggesting, pull them through the firewall, and disconnect them. While doing so repair and seal up any splices he made in all his "handy work". Might just fix up your non start problem.
Old 05-12-2009, 10:58 PM
robertwyoung robertwyoung is offline
Hear the fuel pump prime?
Old 05-13-2009, 01:02 AM
Hi, Thanks for the help..had my brother take a look and there was a loose wire leading to the fuse box as well as on the starter..after he tightened them up it started right away and i am once again mobile. I was told that there are sensors that have to do with the transmission. Are they on the inside of the transmission or on the outside? and could this be the reason that my car jerks when i try to stay at a steady speed? it does it about 50% of the time. its almost like the transmission has an alter ego that's trying to stop me while the other is trying to make me go HAHA sorry only way i can think to explain it.
Old 05-15-2009, 08:31 AM
PappiDread6 PappiDread6 is offline
Send a message via Yahoo to PappiDread6
What transmission do you have? I assuming the Automatic, and what engine do you have 2.5L V6 or 2.0L L4? The transmission sensors (both input and output) are located inside the transmission. The both can be checkt by..
1. Disconnect the input speed sensor connector.
2. Measure the resistance between the input speed sensor side connector terminals 1 and 2.
3.If the resistance is outside 0.3 - 1.2 kilo ohms , replace the input speed sensor.
What driveability concerns are you having with the transmission?
__________________
Yesterday is History, Tommorow is a Mystery, but today is a gift. Thats why it is called present.
Old 05-15-2009, 10:35 AM
Both sensors are located above the Solenoid and Pressure switch assembly. I think it has 6 bolts in it. Also check you transmission fluid color. Needs to be as redish as possible. Smell it and see if its smells burnt.
Old 05-15-2009, 09:33 PM
Hi, its the 2.5 v6 ..when i reach a speed of around 50 kms if i try to stay at the same speed the car starts to jerk unless i slow down or speed up..wont let me stay at a continuous speed. its does it about 50% of the time.
Tags
1997, 95, avenger, burnt, caravan, dodge, engine, input, problems, replace, sensor, smell, speed, transmission, vehicle, wire
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
