Avenger transmission fluid - DodgeForum.com
1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
Old 09-04-2009, 09:56 PM
imbryse7
imbryse7 is offline
Unhappy Avenger transmission fluid
I've looked high and low and for the life of me cannot find out where to put transmission fluid. I know I am low on fluid but don't know where to fill it at. I'm not so sure about all Avengers so it's a FWD manual transmission. Can anyone tell me where to fill at?
Old 09-04-2009, 11:20 PM
bad venge's Avatar
bad venge
bad venge is offline
Section Moderator
Dodge Forum Moderator
Manual does NOT have fluid it uses gear oil
Old 09-05-2009, 12:17 PM
imbryse7
imbryse7 is offline
Default thanks
I know this already. like I said, I know what fluid to use. fluid is any type of liquid. ATF 4.
but I still have no idea where to add the fluid (oil)
Old 09-06-2009, 02:51 PM
Killa200
Killa200 is offline
ATF4 (AUTOMATIC Transmission Fluid 4) does not go in a manual. Like Bad Venge said it uses gear oil. Dealer calls for Mopar MS 9417, but there is probably a comparable replacement.
That being said, the filler plug is located on the left side of the transaxle differential area on a manual, and through the dipstick on an automantic.
Old 09-19-2009, 04:17 PM
22dodge
22dodge is offline
when I raced Neon's I use Redline MTL gear lube
mopar part numbers are 4773167 or MS9417 GM part number is 12345349
realize this transmission is a New Venture trans which was a joint effort between GM and Chrysler in the early 90's. the internals are identical to the 282 GM manual trans.
capacity is 2qts, fill hole is located just above the driver side axle shaft
Related Topics
Thread
Forum
Replies
Last Post
tspeed109
2nd Gen Dakota
4
10-23-2016 02:30 PM
gregjjs
Dodge Avenger
0
08-02-2015 01:06 PM
eagle101
2nd Gen Ram Tech
4
07-17-2015 12:07 PM
HappyDodger
3rd Gen Ram Tech
2
07-15-2015 05:20 PM
5.9Durango360
1st Gen Durango
2
07-06-2015 09:59 AM
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
  • Ask a Question
    Get answers from community experts
What's your question?
Send
