I have the same issue, but I have the 2.0 liter...It says I have a misfire in the primary ignition circuit, but I've changed everything from the plugs, wires, coil pack, crank sensor, cam sensor, even the IAC motor and the TPS...I ran out of things to change and kinda gave up. Car runs fine though, but the CEL comes on every now and then with the same code...
__________________
Tiddy
