DodgeForum.com
DodgeForum.com Home - Dodge Marketplace - Dodge Photo Galleries - Create an Account - Dodge News
Go Back   DodgeForum.com > Dodge Cars > Dodge Avenger > 1995-2000 Dodge Avenger
Thread Tools Search this Thread
Old 11-02-2009, 10:43 PM
bad venge's Avatar
bad venge bad venge is online now
Section Moderator
Dodge Forum Moderator
1998 Dodge Avenger
Vehicle: 98 Dodge Avenger
A good cold air is 7hp ... most of the ram airs especially dual pipes ect run into more restrictions ect due to the bends ect they rob more power then they make
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on Dodge Forums!
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
Old 11-02-2009, 11:22 PM
Ridge Ridge is offline
Vehicle: 2000 Dodge Avenger 2.5L V6
I think I might try to figure out how much hp gain or reduction our cars would get CAI Vs same tubing with one more bend ram air, with the equations the engineer had on that page. I.E. before with cold air intake then after with the filter mounted into the bottom right port boxed in and show picture and gains if it work out being better.
My cold air intake sits very very close to that port. I would only need about 2 inches of pipe then a little larger than 90 degree bend and maybe an inch or 2 more after the bend. Should be pretty cheap to do just a small pipe with a bend and maybe some sheet metal or something along those lines kind of molded around the opening.
small gains aren't a bad thing, but of course bigger gains would be better.
I think I read once anything under 5hp gain you can't feel anyways, but there is a difference even if you don't feel it.
any gain with our cars is a good thing as there are not many options for cheap hp gains
Old 11-03-2009, 10:22 AM
technotitclan's Avatar
technotitclan technotitclan is offline
1996 Dodge Avenger
Vehicle: 96 Avenger
Send a message via AIM to technotitclan
Actualy ram air starts to work at about 60 mph. I installed it with great success in my dakota. Its not going to give you a huge hp jump but done right you should see about +15 hp.
In order to do it right you are going to need to run some kind of piping (flexable plastic inkake pipes they have at auto zone work great) into a SEALED filterbox from any location on the car that is subjected to winds while driving (ie. hood scoop, behind the grille, fog lamp ports...). The idea is that the wind created by the car moving at 60+ mph will force more than normal amounts of air into the engine intake.
There is no way to loose anything by setting up ram air on your car. At the very least it will function exactly like a CAI at low speeds. Also there are no way that bends in the intake will negitivly affect the quantity of air that is moving. If this were true than all the turbo fanatics in the world would be making they're intake as straight as posible rather than running a masive amount of pipes so that they can get a intercooler in exactly the right spot.
Old 11-03-2009, 04:54 PM
ya highway speeds are more why I want more hp. I take off great, but still have to floor it passing on the highway.
i'm going to put it in the fog light port and put a mesh sort of cover in front of it to help keep out bugs and dirt out.
The engineer said something along the lines of at 70mph it adds 1 psi of boost with the ram air which equates to .5% hp so there would be smaller gains at lower speeds but not noticeably at all.
Old 11-04-2009, 11:00 AM
1996 Dodge Avenger
Vehicle: 96 Avenger
Trust me, you will definatly feel it.
Old 11-04-2009, 06:41 PM
bad venge's Avatar
Section Moderator
1998 Dodge Avenger
I felt no difference and you must worry about ingesting water and hydrolocking the motor
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
