Go Back   DodgeForum.com > Dodge Cars > Dodge Avenger > 1995-2000 Dodge Avenger
Sign in using an external account
Register Forgot Password?
1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
96 Avenger won't start
Thread Tools Search this Thread
Old 12-09-2009, 08:38 AM
theonlyfalco theonlyfalco is offline
Garage is empty, add now
Default 96 Avenger won't start
Hello everyone,
I have a 96 Avenger that cranks but just won't start. It was in the shop where it had a new computer put in it, and the mechanic said the timing was fine. He couldn't fix it either.
We have over the past two weeks, replace the camshaft sensor. The crank sensor has been replaced. Changed all the spark plugs, one was fouled out. It's getting fire and fuel. We thought of changing the relays, but since it's getting fuel and fire I figured that wouldn't be it.
What is the deal with these cars, I have spent a lot of time reading the message boards and it seems everyone has this problem. Any suggestions would be great.
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on Dodge Forums!
Old 12-09-2009, 08:04 PM
bad venge's Avatar
bad venge bad venge is offline
Section Moderator
Dodge Forum Moderator
1998 Dodge Avenger
Vehicle: 98 Dodge Avenger
Read the relays post and get the voltmeter out and Check them as well as the CPS testing procedure ,just cause you replaced the part doesn't prove it's good
Old 03-27-2010, 08:20 PM
Dodge*Demon Dodge*Demon is offline
Vehicle: 96 Dodge Avenger
Unhappy Im having the same problem
I have a 96 dodge avenger 2.5 v6. We pulled the motor to repair an oil leak in the rear seal. While the motor was out we replaced all seals and gaskets, scoped out everything, cleaned it up and even repainted it. Motor is good. When we put it in, we got no spark to the plugs. So we replaced the distributor (which has the cam sensor, coil, and rotor button). Still no spark. So we replaced the crank sensor, fully charged the battery and still no spark. The 3 relays on the firewall all click when we turn the key. the fuel pump is working because we can hear it. Everything works when we turn the key. Dash lights, radio, interior lights, headlights and tail lights. But STILL no spark. We even changed out the big computer which I believe is the PCM (if im wrong please tell me so). And still no spark. Anyone know what I can do to get this car running again? PLEASE Im desperate.
Old 03-27-2010, 08:53 PM
bad venge's Avatar
Section Moderator
1998 Dodge Avenger
I'd check for voltage feeding the distributor ... no voltage start backwards
voltage , no spark bad distributor
Old 04-06-2010, 01:44 PM
Avenger1996 Avenger1996 is offline
Vehicle: 1996 Dodge Avenger
what about crank possition sensor?
Old 04-06-2010, 08:31 PM
bad venge's Avatar
Section Moderator
1998 Dodge Avenger
You have to check for voltage first , the voltage feeds the sensors and the distributor/fuel pump ect ect ...You can keep installing parts and without the voltage you'll never ever fix it and waste hundreds of dollars
Old 04-06-2010, 09:04 PM
True that my bad
Tags
avenger, no start
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Join DodgeForum
Advertising
Featured Sponsors
Vendor Directory
Our Sponsors
Internet Brands, Inc.
Contact Details & Emails
Search Engine Friendly URLs by vBSEO 3.5.2
