1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
multi misfire 00 Avenger
Old 01-16-2011, 01:10 AM
senna1's Avatar
senna1
senna1 is offline
Default multi misfire 00 Avenger
I have a multi-misfire on my 00 Avenger. I believe that the starter might be the cause. I traced it to the positive cable and replaced it. The car ran great for a day and then acted up again. If I pull on the positive cable the car will die. If I move it again I can get it to run again. I had replaced the starter about six months ago. I don't know enough about this car so I am looking for help. Do you think this makes sense?
Any help would be appreciated.
Old 01-16-2011, 09:31 AM
bad venge's Avatar
bad venge
bad venge is offline
Section Moderator
Dodge Forum Moderator
A multi cylinder misfire will NOT be caused by the starter... You don't state MOTOR I'll assume V6
Is the CEL Flashing ? If so this is a multi cylinder misfire.
Likely causes are oil in the spark plug holes , Bad Plug Wires, Bad Cap/Rotor or bad distributor
Old 01-17-2011, 12:14 PM
senna1's Avatar
senna1
senna1 is offline
New plugs, wires, cap, rotor, valve cover gsm and seals and also distributor replaced about a year ago
Old 01-17-2011, 12:38 PM
bad venge's Avatar
bad venge
Section Moderator
CHECK the work /// Plugs still dry /oil free ? Check inside the cap/rptor for arcing sparking
Old 01-17-2011, 07:50 PM
22DODGE22's Avatar
22DODGE22
22DODGE22 is offline
I had a misfire on my 2.5 and borrowed a friend's scanner. I found I had 2 cylinders misfiring. One was caused by a bad plug and the other was caused by a bad plug wire (I just had a tune up done a few months earlier)
Quick Reply: multi misfire 00 Avenger
