1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
how fast does a 98 dodge avenger v6 go
Old 10-27-2005, 01:09 AM
98avenger_91's Avatar
98avenger_91
98avenger_91 is offline
Default how fast does a 98 dodge avenger v6 go
how fast does a 98 dodge avenger v6 go because i just got one and i wanted to know what its top speed was?
Old 10-27-2005, 02:53 AM
silvercoupe97's Avatar
silvercoupe97
silvercoupe97 is offline
Uber Moderator
Dodge Forum Moderator
Default RE: how fast does a 98 dodge avenger v6 go
ORIGINAL: 98avenger_91
At a snail's pace...130mph is our factory limit.
Old 11-15-2005, 08:00 PM
avengerboi2950's Avatar
avengerboi2950
avengerboi2950 is offline
I hit 120 before I backed off and still felt like I had alot more room to go faster, but that was when I still had OD. lol
Old 07-09-2006, 01:29 AM
droppedavenger's Avatar
droppedavenger
droppedavenger is offline
i hit 130 cut off my 6 is slightly modified but i got there very fast
Old 07-12-2006, 02:44 AM
scatpackmopar's Avatar
scatpackmopar
scatpackmopar is offline
I am pretty sure I have been above the 130 mark with my 5 speed 420A powered Venge. I have been told that the cut off is 136. I thought for sure I was doing somewhere between 130 and 135 on the speedo going down the backside of a hump in the middle of a bridge. I could be wrong, I was a little pre-occupied with an Acura Integra that was receiving an *** whoopin!
Old 07-12-2006, 04:16 AM
TODD0341's Avatar
TODD0341
TODD0341 is offline
You have an avenger that can beat an integra? Wasnt a type R then was it.........I cant believe how slow my car is..My wifes Taurus is faster.
What is the stock timing for the 2.5L motor? I cant find the info anywhere and that stupid haynes manual is absolutely no help what so ever...it contains less information then I have found out on my own by looking through the car trying to find the various shorts and other little problems.
Old 07-12-2006, 06:27 AM
silvercoupe97
Uber Moderator
The 2.5L is a ~17 second 1/4 mile racer folks...yup, slow.
Todd, what exactly are you doing, lol. I believe the timing is electronically controlled by the ECU and if you're trying to advance it you will need a piggy back called the ICON.
Old 08-11-2006, 09:26 AM
petie_pitbull's Avatar
petie_pitbull
petie_pitbull is offline
My ,99 ES has been up to 125 but ran outta road. Still plenty of throttle left.
Old 08-12-2006, 12:18 AM
silvercoupe97
Uber Moderator
Remember that the stock ES tires are H rated which is a 130mph tire. Unless you changed to a Z rated tire and removed the speed limiter, you're not going to go much faster I wouldn't go past 130mph on H rated tires anyway, nor is there a reason for it unless you're on a track with mods that put you past 130mph.
Quick Reply: how fast does a 98 dodge avenger v6 go
