1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
1997 Avenger stuck in second gear
Old 03-31-2015, 07:23 PM
hickboy63's Avatar
hickboy63
hickboy63 is offline
Question 1997 Avenger stuck in second gear
Hello all,
I have 97 Avenger ES coupe which has a leak to transmission pan (noted). Failing to check status has now caused check engine light to turn on. Upon having code read, it has determined shift solenoid to be either burn out or fried. Temp was greater than 1000 degrees. Any suggestions to following questions: 1) I cant even find a image of the part, does anyone know? 2) where is it located? 3) I need a new one, possibly.
Old 03-31-2015, 08:16 PM
jkeaton is offline
Dodge Forum Administrator
What engine?
Old 04-01-2015, 10:14 AM
smokesxt's Avatar
smokesxt
smokesxt is offline
Front of the trans (by radiator), under the intake tubing.
It's common for them to fail.
Get a new pan gasket and filter while you're at it.
Quick Reply: 1997 Avenger stuck in second gear
