1999 Dodge Avenger V6 2.5 Power Steering Switch Discontinued Please Help
Hello, I love my 1999 Dodge Avenger V6 2.5L - 77K miles - it's been a great car but now have the PO551 code problem and told I need a new Power Steering Pressure Sensor Switch - PSS14 - this part is listed on many auto part sites (US & China) but then when you press button to "purchase" it says "not in stock - not available" so I contacted Standard Motors Corporate HQ's only to be told this switch has been Discontinued...what?? I also tried the list of cross reference parts which are not available either. I'd feel much better finding a new part then a used one from a salvage yard but running out of time. Smog due next month and I want to pass! I'm in CA - Ugh - Please Help. Thank you.
Thanks
RockAuto says "out of stock" and according to Standard Motor Parts it's actually discontinued. I've tried all over the internet (US & Foreign) but no luck. I have also tried finding the cross reference parts with no luck. I'd have to find one at a salvage place and then it would be an old sensor and I'd much rather it be NEW. But it's not looking good. Thankfully my power steering seems normal and it may be that the sensor is just "faulty" but still working. I'll have to get a "part exception" clearance to pass smog (as long as there's no other issues).
Due to the Smog Regulations changing this past May which states a non-diesel car 1999 or older can pass with one "incomplete monitor" I passed smog! I'm in CA so not certain if this applies to other states. As stated in my prior posts the PSS14 power steering sensor switch was discontinued so unless I find one used someday I cannot replace it. I think the sensor is just "faulty" anyways - the code is not PO550 but PO551. I really just wanted to pass along the smog stuff in case others out there are concerned.
