Got a new 1993 Dakota LE 4X4 5.2L, have some questions
So I traded an '83 Nighthawk for this truck, and I have a few questions. I've never had a Dodge, only Fords and Chevy's, so here I go.
First, the bolt pattern is 6x4.5, correct?
Where can I download the service manual for this? I checked the FAQ but didn't see my year there.
Would a body lift kit be good for off-roading or should I just save my money and opt for a suspension lift?
I have more, but I can't think of them at the moment, I'll ask them in this thread again when they come to me.
Sorry if I asked asinine questions, or if the answers to these are in the FAQ, I checked but might've missed it. Thanks in advance!
Also, here is the truck! It has some issues but I'm very happy with it. It has different rims and different size tires all around sadly, but I'm working on fixing that now.
6x4.5 is correct. The FSMs aren't generally available for download but you can usually buy an original on ebay. For shared part numbers use one of the many mopar dealer websitesm..they have the assemblies all detailed....drill down to the drive shaft and then click on it and it will give you a link to all the vehicles that shared that part.
Example http://www.moparone.com/p/Dodge__/DRIVE-SHAFT-PROPELLER-SHAFT/59895884/53005548.html
Example http://www.moparone.com/p/Dodge__/DR.../53005548.html
You've probably figured somehting out by now but if not, I would just buy a driveshaft off ebay. http://www.ebay.com/itm/88-89-90-91-...BXWvFT&vxp=mtr
For example. For that particular one you'd need a new u joint because the caps aren't on one side. Or find one at a yard. Don't know if another driveshaft would fit but I doubt it.
Well, since nobody answered the big question. Body lift is the only option for these trucks. 2" is perfect but do NOT go higher then 3". There was one company that made a true suspension lift for these - Trail master made a 4" lift and it ran about $2k. Other lift options are cranking torsion bars, torsion bar keys, the blocks or whatever you want for the rear. For about $250 you can add 4" give or take if you do the work.
