Need Easy Fuel Line Repair
#32
#33
#34
I emailed Dorman about that 800-035 brass fitting and asked if i could clamp my rubber fuel hose onto that barbed end and he wrote back
"Sorry no as that is for Nylon fuel line and is a smaller diameter then the rubber hose."
Smaller diameter??? 3/8 is 3/8 i thought.
So my favorite idea in this thread is the flare and clamp method for its security and simplicity. As mentioned above ^ I've had good results without flaring but thinking back that WAS with brand new fuel hard line. I should've considered the fact you're using the old hard line and its possible the fit MAY not be as good.
Anyways that's my opinion, this has been a good problem solving thread haha, great many solutions that could work.
#35
thank yall; it figures my line would be 5/16 after asking autozone to order two of the 3/8" dorman fittings. oh well
We can be sure that if i find my right size dorman compression fitting, that it will be secure and not blow off, right? as for the barbed end of the 800-035, if i have to use a smaller diameter rubber line, i can make that work..i think; ha.
#36
OH JOY! When you order those adapters, they come Two in a pack so i got two today. Earlier, i cut off my fuel line with the tube cutter and found it to be as yall say, 5/16" The compression end of the adapter fits nicely but i had to go with 1/4" efi hose to have a tight fit and the whole job should go smoothly.
Is it a bad thing to step down from 5/16" to 1/4" on either side of the filter?
#37
#39
cut the crimped fitting off the hose by hand with a hacksaw blade cutting in line with the rest of the line, with the rest of the old hose as a buffer against going thru the line itself, and then pry the slot you just made open with a screwdriver then pull what is left of the old one off.
Go with fuel injection rated hose and the pressure won't be a problem. Alot of rubber hose says right on it "NOT FOR FUEL INJECTION". Pay attention to this.
#40
It's done! clamped 1/4" hose over the barbs on one side and the 5/16" compression fit on steel line...no leaks. Glad that's done but my truck still randomly stalls goin down the road and one time as i'm bout to merge into traffic, it dies and would not start again so i called for help...no answer..tried again and it started but ran rough then smoothed out and i made it home...later in the day i took my mechanic on a ride and it never acted up once! today i wanted to just let it warm up and it dies after 3 minutes so i'm at a loss.
