Last edit by: IB Advertising
Browse all: Exterior
- Dodge Ram 2nd Gen Why are Wipers Not Working
Guide to diagnose trouble and recommended solutions.
windshield wiper problem
My windshield wipers quit working recently. The fuse is good. I can hear the wiper motor trying to work but nothing happens. I can move the arms by hand. I am trying to remove the access panel to see if anything is hindering it but can't figure out the trick to take the wiper arms off. There are clips and when I pick the arms up a little bit I can get them half out but from there they won't budge. Any suggestions on removing the arms? Hoping the teeth are not stripped!! Any other suggestions why they would not be working?
RE: windshield wiper problem
Ok, I got the wiper arms off. Just had to pull on the arm when the clip was pulled out a bit. Still can't get the access panel off, something is holding it in the middle and I can't see what. I got the screws on the sides and the 5 in the front. The teeth look ok on the wiper arms and on the part that turns them.
Hold the clips out and pry at the base of the arms to get them off....it may take a little effort or the use of a claw hammer (use a block of wood as a backer) but they will come off. I suspect something in the wiper linkage came apart or stripped splines on the shaft.
My wipers stopped working last winter. It caused me to have to do random stops at gas stations to squigie my windshield. All i did to fix it was i unbolted the motor, and I tryed to pull it out a couple times (it wont just come out) and then bolted it back up and it worked.
Trending Topics
my windshield linkage
since everything was off the drive shaft I'm not sure how it all goes back on...
anyone got a picture of how the pieces go back to gether?
thanks
JT
