13 No change in MAP from start to run (help truck wont start)
Old 01-17-2008, 03:16 PM
mariotraci's Avatar
mariotraci
mariotraci is offline
Default 13 No change in MAP from start to run (help truck wont start)
what would cause this?
2.5l
my truck wont start.......gots gas and spark
Old 01-17-2008, 09:47 PM
Crazy4x4RT's Avatar
Crazy4x4RT
Crazy4x4RT is offline
Default RE: 13 No change in MAP from start to run (help truck wont start)
Could be the sensor is dead. You could have a bad vacuum leak.You couldhadbad wires.You could not have enough fuel or spark. You could have bad timing. There is lots of posibiltys. You need to give more info. Does the starter turn? Does it try to start? Did you do any work before it did this?
Quick Reply: 13 No change in MAP from start to run (help truck wont start)
