We have a 1992 Dakota 4x4, 318 v-8, Automatic. We are wondering if the torque converter lockup switch is the same thing as the overdrive sensor. If not, then where is the lockup switch located on truck?
Sponsored Links
This ad is not displayed to registered members. Register your free account today and become a member on Dodge Forums!
No it is not the same thing.
The computer controls when the torque converter lockup. It only gets activated in 3rd gear and up.
There is no such thing as a overdrive sensor. The overdrive is also activated by the computer.
__________________
93 Dakota Was 2wd 5.2 NOW 4X4 5.9RT 33x12.5 6in lift 1/4mile 15.259 85mph over 1ml el 14.2 sea lv. http://www.youtube.com/user/truck93 "No truck should ever be lowerd! NEVER"
In my experience the torque converter only locks up in overdrive. It has never locked up on me in 3rd gear. Its easy to tell when it locks cause the rpms fall by several hundered. It can get annoying between 40 and 50 mph cause it drops the rpms down to around 1100, where the engine has no power. If I'm on roads with a speed limit off 45 I usually kick it out of overdrive so that it won't lock up.
__________________
1995 Dakota 5.2L 4x4 Auto
> Chrysler 9 1/4 in. Rear
> Mopar Performance Computer
You know what I think your right. I checked my book. It said speeds 30-35mph and up, but it didnt spasificly say 4th. But I think so!
__________________
Like I said before, I have never witnessed it lock up in third. It's a computer controlled device just like overdrive. The '95 and lower trucks had hydraulic controlled transmissions with electronic overdrive. The computer only knows to lock the torque converter when it knows its in overdrive.
__________________
__________________
