New Features: Dodge Knowledge Base - check it out & suggest new topics here.
DodgeForum.com
DodgeForum.com Home - Dodge Marketplace - Dodge Photo Galleries - Create an Account - Dodge News
Go Back   DodgeForum.com > Dodge Trucks > Dodge Dakota > 1st Gen Dakota
Thread Tools Search this Thread
Old 12-02-2008, 09:26 PM
freakinoldguy freakinoldguy is offline
My Garage
Default Fuel Question
Hi folks,
I've got a slight conundrum. I own an 88 Dakota, 3.9 ltre 4X4 with the standard 5 speed transmission.
Ever since I've owned the vehicle, I've had a problem with the fuel system. It got so bad I replaced the fuel pump and did a complete tuneup.
The problem is that every now and then when I shut off the vehicle and go to start the vehicle again it'll start but acts like it's starved for gas and will either die or catch and rev high after a few seconds.
Like I said I've replace the fuel pump and filter which helped it when running but did nothing for the starting problem. This isn't a regular occurance but is intermittent and only does it when the vehicle is warm.
Anybody have any idea what could be causing it. ???????????????
Thanks in advance
F.O.G.
Sponsored Links
This ad is not displayed to registered members.
Register your free account today and become a member on Dodge Forums!
Old 12-03-2008, 01:17 AM
wink2873 wink2873 is online now
My Garage
Vehicle: 2001/1988 dakota
Send a message via AIM to wink2873
well next time it happens take off the air hat and have someone try to start the truck. if you're not getting fuel for some reason you wont see any fuel spraying out of the two throttle body-mounted injectors. if you're seeing fuel spray out of there but it still doesnt start, you've got a different problem.
__________________
88 dakota 3.9 5-speed RC. stock
2001 dakota 3.9 auto CC
AIRAID CAI
Dynomax 3" superturbo catback
Hughes Stage one intake manifold
NGK's with minor ignition work
5.9 TB
180Tstat
Next: 4:10's W/LSD, 1.7rr's
2003 Harley Wide Glide, loud
Old 12-03-2008, 11:51 PM
Crazy4x4RT's Avatar
Crazy4x4RT Crazy4x4RT is offline
Offroad Dakota Moderator
My Garage
Vehicle: 93 Dakota
If you hold the gas peddle down a bit does it die? Is the only problem when your idleing? It also may be the IAC Idle Air Control motor. These tend to seize up alot on our trucks.
__________________
93 Dakota Was 2wd 5.2 NOW 4X4 5.9RT 33x12.5 6in lift 1/4mile 15.259 85mph over 1ml el 14.2 sea lv. http://www.youtube.com/user/truck93 "No truck should ever be lowerd! NEVER"
Old 12-07-2008, 04:24 PM
My Garage
Quote:
No it doesn't die but it doesn't rev any higher and then whether the pedal is down or not it suddenly catches, revs and runs okay.
I replaced the IAC, EGR and Fuel Pressure Regulator awhile ago and it didn't help.
Somehow I'm leaning towards an electrical problem but who knows. It only seems to do it when the vehicle is warm, never when it's been sitting for a long period.
Thanks
F.O.G.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
