New Features: Dodge Knowledge Base - check it out & suggest new topics here.
DodgeForum.com
DodgeForum.com Home - Dodge Marketplace - Dodge Photo Galleries - Create an Account - Dodge News
Go Back   DodgeForum.com > Dodge Trucks > Dodge Dakota > 1st Gen Dakota
Thread Tools Search this Thread
Old 12-04-2008, 03:04 AM
contagious19's Avatar
contagious19 contagious19 is offline
My Garage
Vehicle: 2000 Dodge neon
Send a message via Yahoo to contagious19
Default type of suspension
im posting for a friend, is ur rear suspension leaf over axle or axle over leaf?
__________________
Antagonist
Neon is under construction new look coming soon!!!
http://www.cardomain.com/ride/2569968
Sponsored Links
This ad is not displayed to registered members.
Register your free account today and become a member on Dodge Forums!
Old 12-04-2008, 03:49 AM
fox's Avatar
fox fox is offline
My Garage
Vehicle: chevy built like a rock, Dodge built to crush rocks!
4WD= leaf is on top of the axle
2WD= leaf is under the axle
__________________
1993 Dodge Dakota V8 5.2/318 4x4
Old 12-04-2008, 05:06 AM
My Garage
could u lower a 4wd? how?
__________________
Antagonist
Old 12-04-2008, 11:33 AM
Crazy4x4RT's Avatar
Crazy4x4RT Crazy4x4RT is offline
Offroad Dakota Moderator
My Garage
Vehicle: 93 Dakota
For the rear use longer spring shackles, you can take out a leaf from the pack. You can swap around the springs. Since its a 4wd put the leafs under the rearend. But this will lower by 5 or 6in way to much usually. You can buy new leaf springs with lower spring rates. Or heat up your stocks and let them sag a little.
For the front you can adjust down the torsion bars. You can only go so much untill you hit bump stops. If you got a v8 you can get v6 torsion bars.
There are lowering kits, for all I know its all 2wd but its worth a look at. Check the FAQ2 in this section there are sevearl lowering kits listed.
__________________
93 Dakota Was 2wd 5.2 NOW 4X4 5.9RT 33x12.5 6in lift 1/4mile 15.259 85mph over 1ml el 14.2 sea lv. http://www.youtube.com/user/truck93 "No truck should ever be lowerd! NEVER"
Old 12-05-2008, 05:08 AM
My Garage
is it safe to run da leaf under da axle? or is it too much stress on the bolts
__________________
Antagonist
Old 12-05-2008, 04:48 PM
Crazy4x4RT's Avatar
My Garage
Vehicle: 93 Dakota
Its safe remember 2wd is set up this way, you just have to have the correct hardwear. Just get a 2wd setup.
__________________
Old 12-05-2008, 08:36 PM
95_318SLT's Avatar
95_318SLT 95_318SLT is offline
My Garage
Vehicle: '95 Dakota 4x4 318
I just got done swapping the 8.25 axle on my truck with a 9.25 that came off a 2 wheel drive durango. All I had to do to make it work was measure the pinion angle and weld new spring perches on top. It took less than a day to do the whole swap, so it woudnt be much to get new spring perches and weld them on the bottom of the axle. Just make sure you get the pinion angle correct.
__________________
1995 Dakota 5.2L 4x4 Auto
> Chrysler 9 1/4 in. Rear
> Mopar Performance Computer
Old 12-06-2008, 02:35 AM
My Garage
so stronger bolts where da leafs bolt up?
__________________
Antagonist
Old 12-11-2008, 03:43 AM
My Garage
bump?
__________________
Antagonist
Old 12-11-2008, 01:38 PM
Crazy4x4RT's Avatar
My Garage
Vehicle: 93 Dakota
No you dont need stronger bolts. Stock bolts will be fine.
__________________
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
