New Features: Dodge Knowledge Base - check it out & suggest new topics here.
DodgeForum.com
DodgeForum.com Home - Dodge Marketplace - Dodge Photo Galleries - Create an Account - Dodge News
Go Back   DodgeForum.com > Dodge Trucks > Dodge Dakota > 1st Gen Dakota
Thread Tools Search this Thread
Old 12-05-2008, 05:15 AM
91odsami 91odsami is offline
My Garage
Default 93 5.2 transmission swap
I currently have a 93 dakota extended cab 4x4 with an automatic and was wondering what all was needed to change it over to a 5 speed. i have seen many different transmissions suggested from the ax-15 to the nv 3500 also wondering if it is possible to keep the automatic transfer case or if there is a better one. i plan to lift the truck with a good set of 33's with a little more power and just want to know what the best bet would be for a daily driver and weekend warrior. thank you for any information
Last edited by 91odsami; 12-05-2008 at 05:17 AM. Reason: forgot to include information
Sponsored Links
This ad is not displayed to registered members.
Register your free account today and become a member on Dodge Forums!
Old 12-05-2008, 05:58 AM
wink2873 wink2873 is offline
My Garage
Vehicle: 2001/1988 dakota
Send a message via AIM to wink2873
that would be alot of work, you'd have to swap the trans, put in a clutch, cut a hole in the floor for the shifter and mount it and I think you'd need a computer from a truck with a manual trans.
__________________
88 dakota 3.9 5-speed RC. stock
2001 dakota 3.9 auto CC
AIRAID CAI
Dynomax 3" superturbo catback
Hughes Stage one intake manifold
NGK's with minor ignition work
5.9 TB
180Tstat
Next: 4:10's W/LSD, 1.7rr's
2003 Harley Wide Glide, loud
Old 12-05-2008, 03:17 PM
My Garage
yeah i know it would be alot of work but i just put a new front end on the truck and other than the body and the auto transmission there is less than 20k on the rest of it. i really like the truck and have the pedals from another dakota i had i just dont know what the best transmission and possibly transfercase would be the best bet. thank you
Old 12-05-2008, 05:04 PM
Crazy4x4RT's Avatar
Crazy4x4RT Crazy4x4RT is online now
Offroad Dakota Moderator
My Garage
Vehicle: 93 Dakota
Your best bet is a NV3500. They were found stock in dakotas with v8s in 94-96. Just make sure you get a 4wd version. The transfer case is a nv231 these are stock on all dakota all types of trannys and engines. And they are not automatic they are manual shift. Its a strong unit. You will have to do some wireing and computer may put out a code for not reading the auto tranny but It will still run. The ax-15 is for the 4cy and v6. The FAQ has alot of the info on trannys and years and engines. You wil need a good lift to run the 33s. For lift info check the FAQ2.
__________________
93 Dakota Was 2wd 5.2 NOW 4X4 5.9RT 33x12.5 6in lift 1/4mile 15.259 85mph over 1ml el 14.2 sea lv. http://www.youtube.com/user/truck93 "No truck should ever be lowerd! NEVER"
Old 12-05-2008, 07:40 PM
1shotjake's Avatar
1shotjake 1shotjake is offline
My Garage
Vehicle: 92 Dak ex. Cab 4x4 318 Mag
Send a message via AIM to 1shotjake Send a message via MSN to 1shotjake
doesn't the 93 have a 46rh as the stock auto? I would think then that there shouldnt be any computer problems with a swap as the rh is hydraulic.
Old 12-06-2008, 03:35 AM
Crazy4x4RT's Avatar
My Garage
Vehicle: 93 Dakota
The 93 would have 46rh There is only one code that would come up. 37 Torque converter clutch solenoid CKT or park/neutral switch failure Even tho it is hydralic it still has computer controls.
__________________
Tags
1995, 52, dakota, transmission
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
