Will your truck start without you depressing the clutch?
Also, I never bothered to look into how my truck is wired up, but I should see. I assume my cruise control is linked to the switch on my clutch pedal, and if I depressed the clutch in CC it would turn it off? I need to look into that.
This ad is not displayed to registered and logged-in members. Register your free account today and become a member on Dodge Forums!
Sponsored Links
Registered users do not see this ad. Click here to register for free!
Yes. I covered that on page 1 :P. The harness was already there and very easy to locate, and to my surprise, it was very functional.
Please do look at your cruise control wiring if you get the time! I'm still assuming its because of the P/N switch, but I could be wrong.
__________________
Quote:
If you ain't breakin' stuff, you ain't drivin' hard enough
Quote:
Don't argue with an idiot. He will drag you down to his level and beat you with experience.
It might be in the beggining of your thread... but do you have a photo of your park/neutral switch? I don't think I even have one on mine, but if you have a picture I can track down the harness and let you know. Never thought about how the manual trucks operated cruise control.
I don't have a picture, and unfortunately, I can't get one anymore because the harness is in a dump somewhere. The middle wire of the 3 was for the park/neutral switch signal, and the other 2 wires were for the backup lamps. I had to ground the middle wire and hook the other 2 up to the backup lamp switch in the new transmission, so the harness had to go. Lol, the switch turned out to be bad so I still don't have backup lamps.
__________________
