Factory Service Manual
Old 01-12-2013, 11:47 PM
Crazy4x4RT's Avatar
Crazy4x4RT
Crazy4x4RT is offline
The links in this thread are outdated, but the FAQ in this section has the correct links.
Old 03-10-2016, 05:33 AM
DakotaLove's Avatar
DakotaLove
DakotaLove is offline
I can't get any of the links to work... any suggestions?
This is all I get when I click on the posted links for the service manuals.
Old 03-12-2016, 09:10 PM
Crazy4x4RT's Avatar
Crazy4x4RT
The FAQ which is just a few posts above this one has the updated links.
Old 03-13-2016, 06:36 PM
DakotaLove's Avatar
DakotaLove
Thank you! Much appreciated, very generous. I have the OEM paper manuals but it's much quicker to look things up using the pdf version. You can also print out what you need and it doesn't matter if it gets greasy!
Thanks again.
-Ron Love
Old 04-22-2016, 05:47 AM
gaspasser59's Avatar
gaspasser59
gaspasser59 is offline
How can I get in touch with Crazy4X4RT? I was wondering if he can do a swap for me? Converting a 2001 Dodge Ram Sportsmobile 2X2 into a 4X4? I had tried to contact Sportsmobile but they wouldn't touch it because it is not a Ford Van and because they only do 2002 Dodge Ram and up. Thank you. gaspasser59
Old 04-28-2016, 08:19 PM
Crazy4x4RT's Avatar
Crazy4x4RT
Thanks for the offer, but I'm not a mechanic, I just work on my own vehicles. Check for a custom 4wd shop or a get a few friends and have fun.
Old 05-29-2017, 12:00 PM
mpheyse's Avatar
mpheyse
mpheyse is offline
Default Shown Here, not in FAQ
The 95' wiring diagram shown here as
RapidShare has been dead for years
isn't in the FAQ, it goes 94 then 96
Please reupload.
And as this Post is the first Google hit on 1995 Dodge Dakota Service Manual,
It would be nice if you edited the top post, to ADD a link to the
Old 06-03-2017, 01:15 PM
onemore94dak's Avatar
onemore94dak
onemore94dak is offline
Here are the Factory Service Manuals we have. Click the link to download. And go to free user and follow the prompts.
1995 Dodge Dakota PDF
http://rapidshare.com/files/20546689...AN_SERVICE.ZIP
1996 Dodge Dakota PDF
http://rapidshare.com/files/20546066...AN_SERVICE.ZIP
1990 Dodge Dakota Wiring Diagram
http://rapidshare.com/files/20549398...ota_wiring.pdf
1994 Dodge Dakota Wiring Diagram
http://rapidshare.com/files/15954448...omplete_1_.pdf
1995 Dodge Dakota Wiring Diagram
http://rapidshare.com/files/205477308/1995_AN_WIRE.pdf
1996 Dodge Dakota Wiring Diagram
http://rapidshare.com/files/205480159/1996_AN_WIRE.pdf
1990 - 1993 Dodge Trucks Parts PDF
http://rapidshare.com/files/20547128...993_Trucks.pdf
1994 - 1996 Dodge Trucks Parts PDF
http://rapidshare.com/files/205475222/94_96Truck.pdf
46rh (A500) / 42rh (A518) Auto Transmission Service Manual.
http://rapidshare.com/files/205488149/46rh.pdf
1996 Powertrain Diagnostics (Will work for all years)
http://rapidshare.com/files/20554250...iagnostics.pdf
I will add more to this list within the next day or so. Also these links will be posted in the FAQ and FAQ2.
When I click the link I get a bar at the top and the option is to shut off one of NoScripts built in protections. I did so and now nothing loads up I get "Problem loading page" I while back I was able to download the 95 FSM since then nothing will download. It used to go to some google page now its as described.
Old 05-19-2018, 03:47 PM
Cash68's Avatar
Cash68
Cash68 is offline
Does anyone have working links for these?
Quick Reply: Factory Service Manual
