Replacing head gasket, photo
Old 05-09-2009, 10:31 PM
dbilik's Avatar
dbilik
dbilik is offline
Default Replacing head gasket, photo
So I tore into the truck. I had previously found out which head was bad. Just wanted to share the photo of it once I took the heads off. You can see the far right one is clean, and I think I just had a small leak in the head gasket which eventually became much larger once I was in Minnesota. So now I am debating if I should take off the oil pan and remove the piston to inspect it and check the ring. Make sure no more damage is done to it that I cannot see.
As for the heads, I am taking them to be machine, possibly do a valve job on them, and have them magnafluxed to check for small cracks.
http://www.flickr.com/photos/38087588@N06/3517408034/
By the way, anyone know how ot make the photos show up in here without having the link? I now some people use photobucket right?
Old 05-09-2009, 10:42 PM
95_318SLT's Avatar
95_318SLT
95_318SLT is offline
You should just be able to right click the picture and click copy and then paste them into the thread as long as they are hosted online somewhere.
like this...
Old 05-10-2009, 02:09 AM
Crazy4x4RT's Avatar
Crazy4x4RT
Crazy4x4RT is offline
Dang that is clean.
Old 05-10-2009, 03:09 AM
95_318SLT's Avatar
95_318SLT
Originally Posted by Crazy4x4RT
Dang that is clean.
LOL! I said the exact same thing. Those pistons look like they only have 100 miles on them!
Old 05-10-2009, 04:20 PM
Bad96_3.9's Avatar
Bad96_3.9
Bad96_3.9 is offline
my 3.9 looked the same way, maybe even a little cleaner when i put the 318 in, it had 181,000 on it! good ole' valvoline and lucas.
Old 05-10-2009, 04:31 PM
Crazy4x4RT's Avatar
Crazy4x4RT
The piston on the left is clean. But the rest is dirty. That head gaskets gots some sludge. For me it was oily color but no build up.
Quick Reply: Replacing head gasket, photo
