DodgeForum.com
DodgeForum.com Home - Dodge Marketplace - Dodge Photo Galleries - Create an Account - Dodge News
Go Back   DodgeForum.com > Dodge Trucks > Dodge Dakota > 1st Gen Dakota
Thread Tools Search this Thread
Old 05-24-2009, 11:39 PM
dbilik dbilik is online now
Vehicle: 1995 Dakota 4X4 3.9L V6
Default Fuel pressure in 97 318 Dakota?
Title says it all almost. I am looking for the fuel pressure in a stock system on a 97 Dakota with a 318 in it. I have looked up my trucks info and I am running 35-45 PSI on both the V6 and V8 in 1995. My V6 has a return fuel line I believe. The V8 I got does not. I heard that it may require a 100 PSI fuel pump in the 1997 Dakota, but I need to verify.
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on Dodge Forums!
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
Old 05-24-2009, 11:50 PM
dodgerules86's Avatar
dodgerules86 dodgerules86 is offline
Section Moderator
Dodge Forum Moderator
Vehicle: 1996 Dakota 4x4, 3.9L, extended cab, automatic.
Nope. 49.2 +/- 5PSI.
__________________
If parts ain't flyin', you ain't tryin'.
If it ain't broke, fix it 'til it is!
2009 Toyota Corolla S, 1.8L, 5-speed - the daily driver.
1996 Dodge Dakota, 4x4, extended cab, 3.9L, automatic. - my baby
Old 05-25-2009, 12:32 AM
Thanks. I thought I was missing something somewhere. Getting worried over nothing.
Old 07-05-2009, 10:08 AM
mpburris mpburris is offline
I have also been experiencing these same problems on my 95 Dodge Dakota 5.2 ltr 318. The fuel pump is working; however... not been able to determine if this is actual issue with the fuel pump itself, or an electronic/pcm issue, wiring, etc... Not sure if I should just spend the ridiculous $155 to replace the fuel pump or not!? Have already had the fuel pump out, fixed a couple vacuum lines, tested pump for actual working, and truck is still cranking most of the time, runs smooth sitting..., go down the street, put some gas to it, and jumps, missing...sometimes backfiring.., and sometimes, it doesn't even want to crank. Wasn't sure if a fuel pump could give you "inconsistent" operation for a few weeks?, or if it would just one day "not work"? Also, not sure, IF I go get this pressure gage, ck the pressure, it maybe NOT be correct psi.., and IF that would be the pump itself?, or again... some electronic issue? Thanks
Tags
1995, 1996, 1997, 318, 39, dakota, dodge, fuel, line, magnum, pressure, psi, pump, truck, v6, v8
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
