DodgeForum.com
DodgeForum.com Home - Dodge Marketplace - Dodge Photo Galleries - Create an Account - Dodge News
Go Back   DodgeForum.com > Dodge Trucks > Dodge Dakota > 1st Gen Dakota
Thread Tools Search this Thread
Old 06-14-2009, 04:28 PM
dakota_freak1989 dakota_freak1989 is offline
Default wont run under 1000 rpms?
hello my 90 dodge dakota is haveing some issues with running unless its in the 1500 or 2000+ rpm range what would do this ? if i let it idle it just dies when i start it i have to feather the gas pedol to get it to start the injectors work fine i just dont know what would do this ? please any insight or suggestions would be helpfull
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on Dodge Forums!
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
Old 06-14-2009, 05:55 PM
HTRTrash HTRTrash is offline
1996 Dodge Dakota
My Garage
Vehicle: 1996 Dakota
Check your vacuum lines, brake booster line and PCV vacuum for leaks.
Old 06-14-2009, 06:04 PM
Crazy4x4RT's Avatar
Crazy4x4RT Crazy4x4RT is offline
Offroad Dakota Moderator
Dodge Forum Moderator
1993 Dodge Dakota
Vehicle: 93 Dakota
Most likly it is the IAC. Idle Air control valve. They tend to get stuck. Clean it up or just replace. For location check the service manuals listed in the FAQ in this section.
__________________
My Youtube Videos!
"No truck should ever be lowerd! NEVER"
Old 06-14-2009, 06:09 PM
dodgerules86's Avatar
dodgerules86 dodgerules86 is offline
Section Moderator
Vehicle: 1996 Dakota 4x4, 3.9L, extended cab, automatic.
Idle Air Controller. This is located on the back of the throttle body. Remove it and try cleaning it and the passage for it in the throttle body.
If that doesn't work, you will have to replace it.
__________________
If parts ain't flyin', you ain't tryin'.
If it ain't broke, fix it 'til it is!
2009 Toyota Corolla S, 1.8L, 5-speed - the daily driver.
1996 Dodge Dakota, 4x4, extended cab, 3.9L, automatic. - my baby
Old 06-16-2009, 11:46 AM
is it a little gold cilender with a vacuum hose going to it ?
Old 06-17-2009, 09:48 PM
ive looked for quite a while and found out there is no such thing on my throttle body in my manual it dosent have one labeled either mabey its a idle speed controll u mean ? thats the closest i can find to it any more input would be apritiated greatley dont want to see this pickup go to the wreckers
Old 06-17-2009, 10:53 PM
Crazy4x4RT's Avatar
1993 Dodge Dakota
Vehicle: 93 Dakota
Quote:
Yes that is it. Idle speed control unit. Lots of different names. Same function. You can always look in the Online service manuals we have listed in the FAQ in this section.
__________________
My Youtube Videos!
Old 06-20-2009, 07:05 PM
is there a way to test it before i replace it if so how ?
Old 06-21-2009, 05:24 AM
Crazy4x4RT's Avatar
1993 Dodge Dakota
Vehicle: 93 Dakota
Take it off. Push the tip as far in or out as it can go reinstall. Start engine. If your engine dies or idles high and stays, then it is bad. If your engine goes to a normal idle then it is okay.
__________________
My Youtube Videos!
Tags
1996, cleaning, control, corolla, idle, speed, toyota, valve
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
