DodgeForum.com
DodgeForum.com Home - Dodge Marketplace - Dodge Photo Galleries - Create an Account - Dodge News
Go Back   DodgeForum.com > Dodge Trucks > Dodge Dakota > 1st Gen Dakota
Thread Tools Search this Thread
Old 09-17-2009, 12:58 AM
Crazy4x4RT's Avatar
Crazy4x4RT Crazy4x4RT is offline
Offroad Dakota Moderator
Dodge Forum Moderator
1993 Dodge Dakota
Vehicle: 93 Dakota
Ya the 4wd has quite a bit of play. I searched tons at the junkyard all the same. Off subject but 95 318slt what did you use to lift the body up? I used a high lift jacks.
I did the same thing with the wood.
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on Dodge Forums!
__________________
My Youtube Videos!
"No truck should ever be lowerd! NEVER"
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
Old 09-17-2009, 01:10 AM
95_318SLT's Avatar
95_318SLT 95_318SLT is offline
1995 Dodge Dakota
My Garage
Vehicle: 1995 Dodge Dakota SLT 5.2L V8 4x4 5 Speed Club Cab
Lol, I know :P I had used your pics in your album for ideas on how to hold it up!
I actually used a standard floor jack and a large pile of various length 4x4 wood blocks I have. I stepped it up a little at a time on each side until I could clear the tires on the frame.
__________________
Quote:
If you ain't breakin' stuff, you ain't drivin' hard enough
Quote:
Don't argue with an idiot. He will drag you down to his level and beat you with experience.
Old 09-17-2009, 08:56 AM
pashadowops's Avatar
pashadowops pashadowops is offline
Vehicle: 1995 Dakota
Quote:
Originally Posted by 95_318SLT View Post
Lol, I don't know the number of hours, but it could be done in a weekend if you work diligently and know what you're doing. I started by taking off the grill, bumper, everything off the radiator support, the radiator support, then the fenders, then I pulled the engine/transmission in 1 peice, then I removed all the wiring (comes out very very easy in 2 seperate harnesses), then I unbolted the cab, unhooked the steering and lifted the cab up.
Put that way it sounds easy. Maybe when I get my commuter back on the road and next years taxes. My baby just hit 200605 miles this morning. I think its time...
__________________
1995 Dakota Extended Cab 4x4 5.2L Automatic
Old 09-21-2009, 09:05 PM
iamok iamok is offline
This has been a blast watching all of your response. Thank you. But what I have found out since then as that my pitman arm needs to be replaced. So now do I go with mopar and with an after market part?
Old 09-21-2009, 09:11 PM
skyshark186 skyshark186 is offline
Vehicle: 93 Dakota 4x4
I was gonna do TRW for my joints. They arent as expensive as MOOG or mopar, but have a lifetime warranty.
http://shop.advanceautoparts.com/web...SAMS_742520130___
Old 09-21-2009, 09:16 PM
festerw's Avatar
festerw festerw is offline
I'd go for either as long as it's got a grease fitting and you actually use it. FWIW borrow the pitman arm puller and the fork from Advance Auto the one from Autozone is crap. Tighten the puller down as much as possible and then whack the side of the arm with a hammer and it should come off.
__________________
1992 Dakota Ext 4x4 V8, Sno Way 7'6" Plow, Gen II 15" wheels and 31's.
2007 Jeep Patriot 4x4
Old 09-22-2009, 10:49 AM
dbilik dbilik is online now
Vehicle: 1995 Dakota 4X4 3.9L V6
I had play in my steering and it was the pitman arm. It is a pain to get off, definately get a few pullers from your local autozone, and match the puller to the new pitman arm you are buying because its not the standard puller that will work, as usual. With a lot of pounding and some heating I eventually got it off. The pitman arm puller (or wedges) were useless for the pitman arm.
I take my truck to NTB for an alignment when its bad, and when they come back they give me a print out of all the components with play in them, then I replace them and go back.
Tags
1987, 4x4, 93, coupling, dakota, dodge, excessive, intrepid, lifted, loose, play, ram, shaft, steering, truck, wheel
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
