DodgeForum.com
DodgeForum.com Home - Dodge Marketplace - Dodge Photo Galleries - Create an Account - Dodge News
Go Back   DodgeForum.com > Dodge Trucks > Dodge Dakota > 1st Gen Dakota
Thread Tools Search this Thread
Old 11-05-2009, 04:48 AM
byronlenz byronlenz is offline
1989 Dodge Dakota
Default trans problem
i dont know what is going on with my tranny but the od quit working and then about 2 weeks later my trans just started to give out like i har run it out of fluid but i have no trans leaks anywhere and the transfer isnt leaking eather. but when i start it up cold the trans seems to be working just fine untill it warms up can anyone help me with this??? thanks alot.
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on Dodge Forums!
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
Old 11-05-2009, 09:48 AM
95_318SLT's Avatar
95_318SLT 95_318SLT is offline
1995 Dodge Dakota
My Garage
Vehicle: 1995 Dodge Dakota SLT 5.2L V8 4x4 5 Speed Club Cab
Can we get info on your truck? Year, engine, transmission, etc?
The overdrive is electronically controlled, have you checked the fuses and wiring?
What do you mean by give out? Are you saying it slips when you move forward, or it slips while shifting, or it won't shift properly, or something else?
Have you actually checked the fluid level? All you said is there are no leaks.
__________________
Quote:
If you ain't breakin' stuff, you ain't drivin' hard enough
Quote:
Don't argue with an idiot. He will drag you down to his level and beat you with experience.
Old 11-05-2009, 10:43 AM
dbilik dbilik is online now
Vehicle: 1995 Dakota 4X4 3.9L V6
You could burn out the OD bands too. If you check the fluid see if it smells normal or if it has a burnt smell to it.
Also, just curious, what year truck and engine do you have?
Old 11-05-2009, 04:40 PM
1989 Dodge Dakota
its an 89 dakota auto 3spd w/od. i was told that it was a 904 but not sure theres no tag on the trans. it slips all the time when its warmed up. no matter what gear im in. when trying to drive down the road. the trans fluid is not burnt its not dark eather. im going to pull the pan tonight. when it was working it would always shift kinda hard when shifting from 1st to 2nd. the fluid level is good. i have not checked the wires or fuses.
Old 11-05-2009, 04:52 PM
1989 Dodge Dakota
i got codes 32,37,52,54
Old 11-05-2009, 06:21 PM
95_318SLT's Avatar
1995 Dodge Dakota
My Garage
I have an off-the wall thing for you to check. Based on the fluid description you gave, I'm wondering the cooler lines are plugged restricting the flow. Disconnect the cooler lines and make sure there are no clogs and reinstall them!
__________________
Old 11-05-2009, 06:26 PM
95_318SLT's Avatar
1995 Dodge Dakota
My Garage
Quote:
32 EGR system failure
37 Torque converter clutch solenoid or park/neutral switch failure
52 Fuel system rich
54 No Cam signal at PCM
You should try resetting your computer and seeing what codes come back! Because if code 54 is a current issue, the truck wouldn't run at all. So some of these might be old stored codes. But, 37 could be giving you an issue. You should check out both the TCCS and P/N switch connectors and whatever else you can inspect for both.
__________________
Old 11-05-2009, 09:31 PM
1989 Dodge Dakota
ok cool ill do that so how do i go about clearing the codes?
Old 11-05-2009, 09:33 PM
95_318SLT's Avatar
1995 Dodge Dakota
My Garage
Unplug the battery for 10-15 minutes.
__________________
Old 11-05-2009, 10:42 PM
1989 Dodge Dakota
so i just pulled the pan off and it was like i stuck gold there is alot of little copper flakes in the pan. do you know what component is copper in the trans 46rh? i dont want to have to replace everything in the trans. and what i would have to replace cause of the flakes.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
