4 wheel will not engage
Old 02-06-2010, 08:50 PM
asosnoff's Avatar
asosnoff
asosnoff is offline
Default 4 wheel will not engage
Hi everyone, newbie here. I have a 92 Dakota V8 4x4. Just recently it will not engage 4 wheel. feels like low range works, but front axle is not engaging. the light for the indicator bulb will not light, but when I check it with a test light one terminal of the socket has power all the time. No power at the switch on the front axle. open for thoughts or suggestions
Old 02-07-2010, 01:39 AM
Crazy4x4RT's Avatar
Crazy4x4RT
Crazy4x4RT is offline
The front axle actuator is vacuum controlled not electrical. This site will help you a lot. http://www.walt-n-ingrid.com/modifications.html#4x4
Old 02-07-2010, 07:32 AM
asosnoff's Avatar
asosnoff
asosnoff is offline
what if there is no vacuum at all, is the switch on the transfer case
Old 02-07-2010, 07:50 AM
Crazy4x4RT's Avatar
Crazy4x4RT
Yes the switch is on the transfercase. There should be vacuum when engaged in 4wd. But only on one hose I believe.
Old 02-10-2010, 08:15 PM
asosnoff's Avatar
asosnoff
asosnoff is offline
it fixed itself and started working. Bought the vac switch on t/case just in case. stopped working again. put switch in still inop. checked for vac at actuator on front axle, very weak. could find no vac leaks. now 4 wheel light comes on even though 4 wheel does not engage
Old 02-14-2010, 01:37 PM
will4557's Avatar
will4557
will4557 is offline
you can try checking to make sure you front driveshaft is turning when transfer case is engaged. I had the same problem on my 90. I took a piece of weedeater string and made sure all the lines were clear and not pinched and changed the vac switch on mine and it started back working. That accuater on the front is not cheap if that has to be replaced.
Old 02-15-2010, 12:41 PM
asosnoff's Avatar
asosnoff
asosnoff is offline
I have plenty of vacuum to the canister at the front axle, and the drive shaft does turn. I believe it is the canister itself that is bad. can not find one in the junk yard and dealer says it is unavailable. anyone have one to sell or a suggestion
Old 02-15-2010, 01:53 PM
Crazy4x4RT's Avatar
Crazy4x4RT
Junkyard will be best bet. It would be a front axle disconnect Actuator.
Try www.autozone.com www.napaonline.com http://www.rockauto.com/ www.ebay.com
Or try OEM parts site. Go the the FAQ get the part number for it. Then check these sites.
https://www.dodgeparts.com/oe_parts_...e2cf8fa4e8846c
http://www.moparpartsamerica.com/par...?siteid=214583
Old 02-15-2010, 07:26 PM
asosnoff's Avatar
asosnoff
asosnoff is offline
Ok, let's update. bought a vac guage and tested the front disconnect actuator. held vac. on both sides. everything appears to operate properly but still will not engage. 4 wheel light does come on when tring to engage. does anyone know how much the vacuum should be at the actuator
Old 02-16-2010, 01:45 PM
1fast2liter's Avatar
1fast2liter
1fast2liter is offline
the diaphram could be bad.. my truck sat for a yr waiting for a new trans and now wont work in 4wd so i need a new diaphram.
Quick Reply: 4 wheel will not engage
