Consensus on Fuel Pump replacement - drop tank or lift bed?
#21
I did it 4x in my first truck and now in this one. I did both drop tank and lift bed. I cheated and used 8in metal hole saw, marked out pump location and drilled hole CAREFULLY, trimmed with snips, made new bigger patch and screwed in like hatch. Took total with changing pump less than 45 mins. Yes I also have removeable bed liner to cover slight bump from hole
#22
I just did this 2 days ago. I dropped the tank and then lifted the bed. DO NOT DROP THE TANK!!! It is such a pita to get that damned thing back up in there. From holding the tank (empty btw) and trying to get those gosh darn tank strap to line up right while trying to keep the heat shield in place was a nighmare. It was so much easier to just lift the bed. You dont have to take the bed off. Just lift it to the side. 8 easy bolts (a little dirt snack but hey, it comes with having a truck) and a few clips (tail lights) and its up. And I even have a camper shell to take off. It was still easier. Plus the tank is bolted securely in place while you hammer the pump ring off. Just my 2 pennies.
#23
#24
