How to remove front rotors
Old 11-05-2011, 05:21 PM
hogback's Avatar
hogback
hogback is offline
Default How to remove front rotors
can some body give me a step by step explanation i know it sounds stupid but i cant get them off 1989 dakota 2wd
Old 11-06-2011, 12:25 AM
InnerCityHillBilly's Avatar
InnerCityHillBilly
InnerCityHillBilly is offline
take the 2 caliper bolts off on the back of the caliper. the caliper will come off after the bolts are taken off, hang the caliper up so its not swingin around, the rotor will slide off after the caliper is off, if the rotor does not just slide off use a rubber mallet and tap around.
Old 11-06-2011, 06:02 AM
hogback's Avatar
hogback
hogback is offline
it doesn't but i read online that the hub and disk are connected and you take off the spindle nut and the bearings
Old 11-06-2011, 07:02 AM
festerw's Avatar
festerw
festerw is offline
That works for 4wd, 2wd is different.
Here's the instructions from the FSM.
ROTOR REMOVAL
(1) Raise vehicle.
(2) Remove wheel cover and wheel and tire assembly.
(3) Remove caliper and brakeshoe assembly but do
not disconnect brake line. Support caliper on stool, or
box. Do not allow brake hose to support caliper
weight.
(4) On 2-wheel drive models, remove grease cap,
cotter pin, nut lock,nut, thrust washer and outer
wheel bearing. Then remove rotor and hub assembly.
CAUTION: On 2-wheel drive models with ABS
brakes, the tone wheel for the front wheel sensor is
located on the rotor hub. Exercise care
when handling the rotor during service. The entire
rotor and hub assembly will have to be replaced if
the tone wheel becomes damaged during handling.
(5) On 4-wheel drive models, remove stamped rotor
retainer nuts or clips and remove rotor.
(6) On 2-wheel drive models, if rotor will be refinished,
remove wheel bearings from rotor hub so rotor
can be mounted on brake lathe arbor.
Old 06-14-2012, 07:57 PM
scrappydakota's Avatar
scrappydakota
scrappydakota is offline
so if im reading this right, when i order some rotors on my 94 dak sport 2wd i need to order rotor AND hub assembly not just the rotor...correct?
Old 06-14-2012, 10:14 PM
dakota00's Avatar
dakota00
dakota00 is offline
Old 06-14-2012, 11:09 PM
kahanabob's Avatar
kahanabob
kahanabob is offline
my 90 had the hub&rotor together i would bet yours does also. just a few years newer and the rotor cam off the hub.
Old 06-14-2012, 11:31 PM
scrappydakota
nice breakdown pic looks like rotor and hubs it is
thanks
Old 06-14-2012, 11:59 PM
volaredon's Avatar
volaredon
volaredon is offline
you dont need to specify "hub n rotor" thats the only way they come; the hub n rotor are all one piece.
I was junking a couple weeks ago and saw a 95 there, with shiney brand new rotors. I couldnt leave them behind they are in my garage as spare parts now. $15 apiece.
it wouldnt hurt to pull em apart and repack the bearings at least... bearings and seals are cheap to buy but if they burn up due to lack of maint., spindles are a PITA to change.
Old 10-03-2012, 11:00 PM
dondons1984's Avatar
dondons1984
dondons1984 is offline
where did you get hat break down puck? I'm looking for those kinds of pics.
Quick Reply: How to remove front rotors
