Ball joint just slides out of control!!
**Ball Joint just slides out of control arm!!
So I have two problems.
My suspension was shot and I am working through replacing everything as this truck was not very well taken care of before I bought it.
I pressed out the upper ball joints and had a mechanic press in the upper bushings. Sadly they had to reuse the original shroud.
Now that it is time to put them back on a 1st set of ball joints from summitracing.com just slid in. They slide back out and I can twist them.
I was wondering if anybody else has had this problem and what possible solutions are out there.
My 2nd problem is the lower suspension bumpers (bumper jounce part #04322534) are falling apart on the driver side and gone on the passenger side. Does anybody know where to pick up the bumper jounce at a price that isnt $50 shipped?
Thanks in advance
Thanks in advance
The upper ball joints are not a press in. They thread in. The bottoms press in. If you pressed out the top ball joints you probably destroyed the threads. Your only option now is a junkyard replacement control arm or fit in the new ball joint the best you can then weld it to the control arm.
$hit!!
I had no idea the uppers were thread in! I already had the bushings pressed in how much do you think it would cost to weld in a pair of ball joints?
At this point it is either buy a new set of control arms from a junk yard and have a new set of bushings pressed in and thread out/in new ball joints or find somebody to weld them im....
thank you crazy.
thank you crazy.
