Back Up light socket (bulb holder) for my '92 Dakota
Where can I find some new rear back up light socket (bulb holder/pigtails) for my '92 Dakota? They are getting so rusted out that the driver side has lost its ground and doesn't work anymore and the passenger side is getting close. I've searched the 'net high and low and can't come up with anything solid. The only other option I have is to look at a local junk yard, but there's no guarantee that they won't be in any better shape.
In 2009, I found the rear turn signal pigtails (bulb holder) on autopartswarehouse.com but they don't seem to carry them anymore.
Last question, will a turn signal bulb socket work in place of the back up? The back up socket is a two wire and the turn signal is a three.
Thanks!
Mike
Thanks!
Mike
When I'm looking for parts that are harder to find I sometimes check some manufacturer catalogs first, then find out who their retailers are.
That way, I can order something the retailers don't normally stock.
For sockets, coonectors etc.:
JTT has most of that type of thing. Either them or the Standard Brand division of Standard Motor Products (SMP).
Here's what I found with a quick check of JTT's retail website:
http://www.thebestconnection.com/sin...uct_Code=2879F
http://www.thebestconnection.com/sin...uct_Code=2571F
Looks like you can order them online directly in addition to contacting them for the name of a local retailer.
If you check the catalog, under the products menu of that site, you will get a photo of all the connectors they sell. Sometimes the connector is not listed specifically for your vehicle, but they actually sell it.
It's always good to compare the actual photo and info and not rely on the accuracy of ANY manufacturers application database/listing.
EDIT/UPDATE: My most recent example of that was trying to get new motor mounts for my 3.9 4WD. All the listings I found were wrong.
Thanks for the info RobertMc. I'll perhaps give them a try. What I really need is just the housing, the wiring is in good shape. I'll have to see if the turn signal/stop light housing will fit where the back-up housing goes. If it's interchangeable I may just buy the turn signal housing and rewire it.
Mike
Mike
