I have a set of 32x11.50x15 tires. My 94 Dakota is 2 wheel drive. Would these tires fit without a lift? I read somewhere I could run 31x10.50x15 on it. I will use the factory rims.
I ran 31's on my old 2wd 96 4 cyl dak but I ran spring spacers in the front (the kind that go on top of the spring) the back was fine and this was on factory 5 star rims... 32's would work on the rear but I dunno about the front Id see if that tire shop would let ya test fit... most places will to get the sale
32's rub on a 4x4.. so i dont know.. i had 32X11.5/R15 on the stock 6 wide.. it rubbed on my 4x4 with torsion bar crank on the front(2 inch lift roughly) but barelly and they rubbed on frame when turning at full turn otherwise not much 2wd is lower is it not? , rear is not a problem
A 2" leveling kit should for 32" tires. I'd get some wheel spacers if sticking with stock rims. also if you like to play off road you might want to smack the corners of your fenders to play it safe
