Difference between 1987 2WD frame and 4WD
Old 08-20-2014, 08:53 AM
marsal80's Avatar
marsal80
marsal80 is offline
Default Difference between 1987 2WD frame and 4WD
Does anyone know what ill need to convert an 87 2WD to 4WD in terms of the frame?
Old 08-20-2014, 09:36 AM
92DakotaClub's Avatar
92DakotaClub
92DakotaClub is offline
like I said in your last post.. its not worth it unless you want to go custom solid axle build.. the time and effort to install a Dakota iFS on a 2wd isn't worth it since dang near everything from the center of the frame to t he front is different let alone the weak front differential
now to build a Solid axle conversion isn't as bad but still requires a lot of fabrication.. im gonna be doing this eventually to a 91 2wd extended cab but I bought a Jeep Tj and its taking all my money lol
you can do what Crazy did and swapped his body from his 2wd to a 4wd frame if you can find one ..
in any account its not gonna be simple but easiest way would be a body swap to a 4wd rolling chassis.... any other direction will require a lot of fabrication and building
Old 08-20-2014, 08:57 PM
Crazy4x4RT's Avatar
Crazy4x4RT
Crazy4x4RT is offline
2wd and 4wd frames are way to different to try to take parts off one or another. Different suspension types front and rear. I got a complete 4wd frame for my motor and body style and swapped my body, bed, motor on to the 4wd frame.
If your truly dead set on a 4wd swap then it will not be easy.
The only easy way is to sell the truck and buy a 4wd.
So here are you options for a 4wd conversion.
1. Sell your 2wd, buy a 4wd. EASY!
2. Do a body/frame swap just like I did. Easy to do, lots of time/space/parts needed. Mostly bolt on, no welding necessary. Click HERE
3. Do a SAS Solid/Straight Axle Swap, 100% custom tons of cutting and welding necessary. Hard to do, tons of time, and way more $$ than you think. I did this too, Click HERE
Take your pick!
Old 09-07-2014, 06:29 AM
big boy's Avatar
big boy
big boy is offline
i got an 88 4x4 frame if your interested
Old 09-07-2014, 08:48 AM
OMGnanerpus's Avatar
OMGnanerpus
OMGnanerpus is offline
Go for a solid axel. Easier to lift more, and will give a better ride after being lifted
Quick Reply: Difference between 1987 2WD frame and 4WD
