Broken tail housing
Broken tail housing
So I'm doing the clutch on my 93 and in the midst of putting the trans back in I tightened up the mount plate, caught the head of the lowest tail housing bolts, and cracked the housing at one bolt. For now I have rtv and jb weld that I'm praying will stop the leak, but does anyone have a junk ax15 laying around?
Also, is it as simple as pulling the bolts out of the case? Anything else I should look for? Thanks.
