Trouble with a 2001 Dodge Durango misfire... 4.7L v8
Old 07-15-2007, 03:55 AM
dlspeed_inc's Avatar
dlspeed_inc
dlspeed_inc is offline
Default Trouble with a 2001 Dodge Durango misfire... 4.7L v8
Hey all. Just joined this forum because my parents have a 2001 Dodge Durango with the 4.7L Magnum V8 that has been giving us hell the past couple of months, and I have run out of ideas and they are ready to give it to a shop to tear apart and I would like to save them money if at all possible.
What It's Doing:
About 2 months ago, my step-mom came home from wrok complaining that the the car was overheating and she was scared to drive it in town anymore. Upon further inspection we noticed that there was a ton of coolant leaking, so my dad, being the "master mechanic" he is, runs out and buys a new thermostat and has me install it for him. Drive it around, bring it back, still leaking. He goes to fill up the radiator and I watch as he pours it in the top and it runs right out the bottom. Futher inspection finds that the radiator has rotted through. $160 and a new radiator later, car doesn't leak anymore, but since doing that we have noticed the car making a loud tapping noise between 2k and 3500 rpms when under a load. If you are in park and rev, you don't hear the tap.
I used to own a Ford Probe, and it had developed a stuck lifter from when my parents were driving it and ran it out of oil (had a leak they claim they didn't know about), and the lifter tapped thereafter. Didn't think anything about it, but then a few days later we changed the gas cap from a pre-existing CEL and when dad cleared the codes we found that the car also popped a CEL for P0306, a misfire in Cylinder 6, and a few different CELs for the EVAP system. So I traced the vac hoses and found about 6 hoses that were either cracked or completely split, and got rid of the EVAP Codes. However, this misfire will not go away. It can only be heard from 2k to 3500 rpm when accelerating (let off the gas at 3000 rpm and you can't hear it anymore). Also, I noticed when test driving it again tonight that if you are in a low RPM, it is very sluggish when you accelerate and it goes to downshift. Once it downshifts it's fine, but right before it wants to bog slightly. Aside from the bogging before downshift, the car has no performance weakness.
What we've done:
Replaced All Vac Hoses (due to EVAP Leak)
Spark Plugs (replaced with Champion OEM)
Cleaned Coil Packs and switched pack from #6 to #5, no change
Cleaned Injectors and switch injector from #6 to #3, no change
Checked Fuel Pressure, it's fine
Changed All Fluids
We are really running out of ideas. It's not getting expensive yet, but we are running out of the cheaper fix ideas. Also, when I pulled the #6 spark plug today to check it's condition, it had unscrewed itself someone. When I installed them a month ago, I torqued them all to spec, so I am not sure if it making it's way out is a symptom of the problem or what. Car drove the same after torquing it down again, and the plug looked fine. Had been firing no problems.
Also, the CEL only comes on after about 45 minutes of driving. I drove into town while testing it, got food at Taco Bell, and came back before it finally came on.
Anyone got any ideas? Searching has not turned up anything I haven't tried, except one that was from 2002 wiht a guy talking about Dodge having a recall due to several claims that the Durango heads were cracking between the Intake and Exhaust Valves near Cylinder 6. Really hope that's not it, but if I check this after I replace my Fuel Pump in the Jeep (why does everything have to break at once?), then I guess I'll disconnect the HVAC lines and pull the valve cover to check it out...
All help is GREATLY appreciated... Will offer a 10% discount good off any products on my website to anyone who gives advice that leads to us fixing this without a mechanics bill... (Truck parts available upon request)
Old 07-15-2007, 10:58 PM
IndyDurango's Avatar
IndyDurango
IndyDurango is offline
Default RE: Trouble with a 2001 Dodge Durango misfire... 4.7L v8
You had a leak.
You fixed it.
Now there is motor noise.
IMHO, Sounds like an obvious overheat and warped or cracked heads issue now or worse.
IndyDurango
Old 01-31-2012, 05:32 AM
Steve78's Avatar
Steve78
Steve78 is offline
Had the same problem with misfires on cylinders 3 and 6. Pulled the valve covers off yesterday and the exhaust rocker arms had slipped off. I compressed the springs and slipped the rocker arms back in. As of now the problems seems to be fixed, although I'm not sure what caused it.
Old 01-31-2012, 07:30 AM
Bobman's Avatar
Bobman
Bobman is offline
Pull the valve covers & look at the rockers / springs for #6 cyl to verify nothing is wrong. Do a compression test as well as a leakdown test and compare # 6 to the others.
I'd tend to agree with Indy though, sounds like an overheat caused a more serious problem. 4.7's can't tolerate overheats very well and tend to damage the headgasket or warp / crack the heads.
What kind of mileage is on the engine?
Bob
Old 01-31-2012, 11:42 AM
otgarzà's Avatar
otgarzà
otgarzà is offline
Bob
+1. Checking under the valve covers is good route to go and see whats in there
Old 01-31-2012, 10:21 PM
hydrashocker's Avatar
hydrashocker
hydrashocker is offline
+1 Bob
Old 01-31-2012, 11:58 PM
master tech's Avatar
master tech
master tech is offline
Site Moderator & Tech
Dodge Forum Moderator
I also agee to remove the valve cover and inspect the rockers. The reason the rocker came off from post number 3 is because the valve seat drop on the cylinder head, causing the valve to stay open and when the cam came around the rocker fell off.
Old 02-01-2012, 03:29 PM
hydrashocker
I have also seen where the cam comes off because of ware.
Old 08-31-2012, 03:40 PM
cristian1967's Avatar
cristian1967
cristian1967 is offline
Default 2001 Durango 4.7 overheated, misfired and now it does not start
The upper radiator hose broke while i was driving it and the truck overheated. Once I replaced the hose and refilled the cooling system the truck started but it was missfiring and making lots of noise. I did remove the valve cover and one of the lifters had came out, i did put it back on place and try to restart the truck but now it just wont start. Any ideas or suggestions< someone told me to replace the ecm but I want to make in sure that it is not something else.
Thank you
Old 09-01-2012, 12:59 AM
Duralude09's Avatar
Duralude09
Duralude09 is offline
back when i was at a technical school a guy had tore down his engine and put it back together started it up and looked like it ran fine but it had a miss. turns out one of the rockers was loose and upon tightening it the truck stalled and took a bit to fire back up. try spraying some ether and see if that gets it going
Quick Reply: Trouble with a 2001 Dodge Durango misfire... 4.7L v8
