code p0320
Old 03-03-2008, 12:53 PM
lashcraft's Avatar
lashcraft
lashcraft is offline
Default code p0320
Last month while sitting in idle my dodge durango just died the check engine light came on then went back off the same day, it started right back up and I didn't think much of it. Just last week it did the same thing but this time was a little harder to start, and the check engine light stayed on until the next day. This time I checked the codes and got the p0320 with the message (ignition/distributor engine speed input circuit). Other than those two occassions the car is running fine, with no other codes showing. Does anybody have any ideas on where the problem may be and how to fix it?
Old 03-04-2008, 01:51 PM
scientist's Avatar
scientist
scientist is offline
Default RE: code p0320
More details please, year, mileage and engine info needed. Could be a number of things causing the problem, But I'd start with the ignition coil first, then distributor cap (if you have one) spark plug wires, and finally plugs
Old 03-04-2008, 08:06 PM
lashcraft's Avatar
lashcraft
It is a 2001 4.7L V8 automatic. 125000 miles.
Quick Reply: code p0320
