DodgeForum.com
DodgeForum.com Home - Dodge Marketplace - Dodge Photo Galleries - Create an Account - Dodge News
Go Back   DodgeForum.com > Dodge SUVs > Dodge Durango > 1st Gen Durango
Thread Tools Search this Thread
  #21
Old 02-16-2005, 11:42 PM
Kensai's Avatar
Kensai Kensai is offline
Vehicle: 2000 Black Durango R/T
Default RE: durango r/t
Quote:
ORIGINAL: b_smith_r/t
hey guys,
i currently drive a 99 dalota r/t with the 3.92 gear and average 17-18 on the highway at 75 mph. I drove that from NC to TX and it got the same all the way there and bck.
Also my truck says nothing about having to use premium fuel at all but i do use mid grade here in NC (89) and no pinging or detno. i have flows and a custom hand built air intake. I run about 2200 rpm at 70 mph. So i gues where all a little different -lol
B-Rad
99 Kota R/T
Seems like your Dak eng/tranny closer matches up to mine as my pic shows around 2200 at 70 mph. But the 2001 thru 2003's, I guess they have a slightly taller overdrive gear and they are barely pushing past 2000 rpms at 70 mph.
I'll find the page in my 2000 manual that states premium required and take a pic of it. Will also take a pic of my fuel door that shows premium required sticker.
I am now pretty sure that requiring premium for highest performance must be based on what geographical area and altitude you live in?
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on Dodge Forums!
__________________
Black 2000 Durango 5.9 R/T, Infinity Reference 6012i, Clear Headlight lens,
Fastman 52mm ThrottleBody,Fastman custom built Tranny,Castrol Full Syntec,
OEM K&N Air filter,Monroe Reflexes,BFG LongTrail Touring T/A's,180 Stat,
Champion IR Truck Plugs,Hypertech III (87 oct),Custom Made Ram Air Intake,
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
  #22
Old 02-27-2005, 09:08 PM
Rick980 Rick980 is offline
I have a 2003 R/T 250 HP 345 Torque.....living in Canada, purchased it here also. No mention of using premium grade fuel, runs great other than mileage, no ping or knock.
  #23
Old 02-27-2005, 11:53 PM
Last Of The R/Ts Last Of The R/Ts is offline
I think we have clearly established that not all Durangos require premium grade fuel. There are a select few that have been unfortunate enough to receive some of these. It is just a case by case basis.
__________________
2003 Dodge Durango R/T
  #24
Old 02-28-2005, 11:41 PM
b_salgado b_salgado is offline
02 R/T here. Only 28,000 miles on it. No premium fuel required either. As for the RPM issue... I played with it on Thurs night. At 64-66 MPH The tach reads 2000 RPM's. At 70 it is 2200-2300. 3.93 gearing.
__________________
Bryan 2002 Durango R/T
  #25
Old 03-03-2005, 05:41 AM
71GTX 71GTX is offline
I would say the small difference you all are seeing might be the tires. They might not have the same tire height. This could account for higher, lower RPM's on the highway, and milage. I have a 00 R/T with a new tranny, headers and knock off KN unit. It only gets 13-14.5 no matter how I drive it. It got 13 towing my Roadrunner from TN a few weeks ago. It has a little lower profile tires, so it takes off fast and reads higher RPM's on the highway. I personally love the AWD vs the reg Durango. Have had both, and the R/T's are way better with weather conditions. A better G rating also side to side. Peace
  #26
Old 03-07-2005, 08:43 PM
Kensai's Avatar
If it is the tire height, I do not think it would change the relationship between the RPM's and the speed reading on the speedo and rpm gauges as they are geared or calibrated on the computer side. So lets say you change the tires, if you do 70 mph according to your speedo, your speed will either be slower or faster than what the speedo says based on the height of the new tire. Taller than OEM tires will result faster mph than what the speedometer says, shorter height than OEM tires will result slower than what speedometer says. If speedo is calibrated to OEM tires and you bought oem replacment tires, your speedo should be on the money on actual speed on speedo.
__________________
  #27
Old 03-08-2005, 01:43 PM
cardfan cardfan is offline
Quote:
ORIGINAL: Rick980
Here is what my owners manual says... (been meaning to scan this since this topic came up). My friend has the Dakota R/T and told me that his too says that he only has to use 87 octane but after having him bring his book in, he did not read the entire page... His says the exact same thing as mine does... When he saw this picture and the little "87 Octane" emblem he just stopped reading, assuming that it was fine... Dodge is lazy, they only make one maual for all model each year...
Note the "exect for R/T model" reference...
And the manual cover...
  #28
Old 03-08-2005, 01:49 PM
Kensai's Avatar
Just think, I wonder how your R/T durangos would perform if you were actually using premium fuel that these R/T's were designed for?
__________________
  #29
Old 03-11-2005, 03:39 AM
Just out of curiosity I peeked at my manual today and it says the exact opposite of what is posted above. It informs me that the use of Premium fuel is NOT recommended and can result in poor engine performance. I can post pics if someone really wants to see it. I was just too lazy to grab my camera.....
__________________
  #30
Old 03-15-2005, 06:47 AM
Exactly what mine says.............may harm engine. I am not going to scan it. Mine is a 2003 and that is what the manual says. Makes no exceptions for R/T. I remember something about my 2000 Durango I had with the 4.7 l mentioning that if you used premium too often that you may have to continue to use it or you will experience spark knock or something to that effect..........like an addiction. I believe myself that any vehicle would probably perform better with some more octane but I am happy with how my D goes and well the price difference and the price alone for gas right now, I don't want to start something that I have to keep up....
Tags
01, 47, 87, 91, air, dodge, durango, filter, fuel, gear, kn, mpg, octane, ratio, rt, timing
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
