NV233 AND NV244 ?`
Old 12-12-2014, 05:57 PM
hydrashocker's Avatar
hydrashocker
hydrashocker is offline
N8ech<----Yea, there is no ABS sensors on the T-case, there is only a range sensor on the manuals cases that is. The 2 wheel ABS is in the transmission output sensor, and top of rear diff. In 4 wheel there are sensors on each front wheels, transmission output sensor, and top of rear diff.
As for installing different size tires on AWD, well I would NEVER do that. The front and back turn at the same time, you would just put excessive wear into the T-case.
azcrom<----The 242 does have a 2WD option. The AWD case is the 244. Also, comparing the 1998-2003 Durango's to 2004+ is like comparing a base ball to a wall, completely two different things wit completely two different parts. There is no 2WD option on the 244 AWD case, it's entirely a different case. And it's not electronic, the internal manual switch is put into position by and electronic motor. Adding electricity will not create new gearing.
Old 12-14-2014, 12:44 AM
azcromntic's Avatar
azcromntic
azcromntic is offline
I did not say the 242 was AWD; I said it has 2WD whereas 244 doesn't. And I already knew the 244 is AWD. Regardless, the wiki pages on New Venture, plus some other sites, seem to indicate that 242 is basically a 244 with a different coupler and no electronic shift motor. So my question was why doesn't the 244 have 2WD?
Old 12-16-2014, 03:28 PM
hydrashocker
Originally Posted by azcromntic
I still want to know if there is some electrical signal I can send to my 244 and have it shift into 2WD. Or...another thought....maybe I can just put a manual shifter on the NV244 out of an older 00-03 D and get the 2WD? Whatever.
This is what I was referring to. Anyway the answer is no.
On the main shaft there is a differential in the center of the case. One has a coupler to disengage the front axle and one does not. Yes they use a lot of the same parts yes, but there is some slight differences inside and out.
Old 11-07-2015, 06:21 PM
Gizmotech63's Avatar
Gizmotech63
Gizmotech63 is offline
Default I've have the same issue
My nv244D casing cracked and and nothing worked. Could find a used one without the exaggerated pricing. SO I've chose to put in the nv233D all is lining up the transfer case goes on but the remaining 1/2 inch it won't go no further. Not sure what the issue there is. Help
Old 11-14-2018, 10:53 PM
alandjanedavis@live.coom's Avatar
alandjanedavis@live.coom is offline
New Member
Default No-swap 244 guts to a 233 case
[QUOTE=n8ech;1351635]Nick
Externally, both cases are the same.I cansay for a fact that either one is a bolt in swap.
The NV233 is a two speed part time 4x4 case that cannot be used on hard surfaces. The NV244 has a mini differential inside that allows full time 4x4/AWD operation on hard surfaces as well as a 4Hi and 4Lo setting.
I made the swap from part time to full time back in Feb. of 2007, and have had no issues.
The AWD is great because you don't slip and slide when its wet out, and the fuel penalty runs anywhere from none to 2mpg depding on your driving style.
Don[/QUO
Great threat Don, just an additional note, NV244 guts cannot be placed into a NV233 case because of the range selector differences; the NV244 Range selector will not travel through the ranges because the case buildups will stop the travel. The 233 case is built up to accept the Shaft Rail, whereas the 244 lower fork will not seat for the buildup.
Quick Reply: NV233 AND NV244 ?`
