So I just got my 1999 Durango from a family member. There's only a few things that need to be done...no biggie, I need the room. So when I was on my way home, I went to brake and the seat slid forward (not all the way) a little bit and then slid back to where I had it when I accelerated. What could be the problem?? I've done searches on here, but haven't really found anything relating to this issue....or I have found postings, but no actual responses as to how to fix it. The seat has never really needed to be moved until now because he was the only one that ever drove it. Thanks for any help you guys can give me!!!
This ad is not displayed to registered and logged-in members. Register your free account today and become a member on Dodge Forums!
Sponsored Links
Registered users do not see this ad. Click here to register for free!
Sounds like the mechanism is a little sticky from not being used for so long, and it may just be that when you moved it you didn't get locked in all the way. There might not be anything wrong with it that a little grease couldn't take care of. You never mentioned if the seat was power or manual.
__________________
2002 Durango SLT 4x4 5.9L
2001 Jeep Cherokee Sport 4x4 4.0L
1996 Jeep Cherokee Sport 4x4 4.0L
well known D issue I'm afraid...
surprised you have an electric seat on a 99...I retrofitted one on mine...
search the web...I have a web address where someone has specific instructions how to fix, but its at work.
I'll try and post it here for tomorrow...
My driver seat is now moving slightly forward when stopping and moving back when accelerating and is becoming annoying. I check out the link above and it looks like it requires some welding which I do not have access to and do not know of anyone that has a welding equipment to make this fix. Has anyone attempted to fix this problem in another affordable way?
__________________
Black 2000 Durango 5.9 R/T, Infinity Reference 6012i, Clear Headlight lens,
Fastman 52mm ThrottleBody,Fastman custom built Tranny,Castrol Full Syntec,
OEM K&N Air filter,Monroe Reflexes,BFG LongTrail Touring T/A's,180 Stat,
Champion IR Truck Plugs,Hypertech III (87 oct),Custom Made Ram Air Intake,
My '98 had the same problem - annoying as hell. I finally took it to a Dodge dealer and they had to replace the entire mechanism. No problems after that. At that time I had an extended warranty - thankfully. I don't know what the charge would have been otherwise. I would think you could purchase the mechanism and replace it yourself as long as you already have the seat out. Shouldn't be too difficult. Better than messing with a band-aid fix.
__________________ 1998 Durango SLT 4X4 5.9L
HD Transfer Case, tow package, 3.92:1 LSD,TBS, K&N Filter, High Flow Exhaust, HyperTech Tuned for 87 Octane, General Grabber HTS P255/70R 16", Super Spring for Towing, Westin Push Bar (for Fords & Chevys).
Another possible problem that I found on my '98 was that the little plastic ball mechanisms on the power adjustment break. They are flimsey, and just a bad design.
I went to a pick-n-pull, and bought a replacement seat for 20 bucks. I wook the parts off, oull my seat, and swapped them out. Then, I out the funky old seat back together, wleded it, and use it now, as a shop seat, in my garage. Double bang for your buck!
Hate to rehash a old post but my driver's seat is rocking a little more than usual to the point where it is very annoying. It used to move slightly. Now it is moving as much as 1/2 inch back and forth.
Anyone have any other alternatives to fix this other than replacing the whole thing or welding the brackets to the rod based on Bill's fix?
__________________
