DodgeForum.com
DodgeForum.com Home - Dodge Marketplace - Dodge Photo Galleries - Create an Account - Dodge News
Go Back   DodgeForum.com > Dodge SUVs > Dodge Durango > 1st Gen Durango
Thread Tools Search this Thread
Old 10-14-2008, 09:26 PM
Durango03's Avatar
Durango03 Durango03 is offline
2003 Dodge Durango
Vehicle: 2003 Dodge Durango 4x4
Send a message via AIM to Durango03 Send a message via Yahoo to Durango03
Default Autolite Copper plugs ok?
4.7 "D" They were on sale at Pep Boys for $0.99 a peice... Just wondering?
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on Dodge Forums!
__________________
Sean
'03 Durango 4.7
'97 Avenger 2.5
'76 Cobra II 5.0
'78 Mustang II 2.3
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
Old 10-15-2008, 12:01 AM
MAGIC84's Avatar
MAGIC84 MAGIC84 is offline
2003 Dodge Durango
Vehicle: 03 DURANGO SLT
Default Autolite Copper plugs o.k
I have had the Autolite Coppers in for almost a year (approx 12k miles since install) No issues, starts right up, good cruise, and good smooth response. I wasn't as fortunate for price though but it is still a good plug. There is a very common recommendation to stay with OEM plugs, just something unique to this engine. I would strongly consider the OEM recommendation from some of our more senior posters, but from personal experience I can state that I have had very good luck with my copper. Also I would recommend based on personal experience to stay away from the Platinum plugs of any type. The Autolite Coppers were a replacement for the Autolite Platinums after only about two months.
As a side note for this engine, I am not sure of your experience with this engine but I will have to warn you that the # 8 plug is exceptionally difficult to remove/replace. I am also not sure of that your tool collection but at least in my case the #8 required a good assortment of socket, flex drives, and extension. If I remember correctly it was a 5/8 deep spark plug wrench, universal, and a 6" extension, do not quote me though it was early December. The universal and extension is definitely I am just not 100% on the socket size.
Also since each cylinder has its own coil, be careful to make sure they do not get damaged.
If you got them for .99 that is a $8.00 plug change, pretty cheap by todays standards.
Good luck!!!
Steve
__________________
2003 DURANGO SLT 4X4 4.7 3RD ROW LEATHER SONY XM/SIRIUS STEREO MICHELIN X-RAD LT BOSCH WATER PUMP DURALAST C-MAX BRAKES DURALAST ROTORS MAGELLAN MAESTRO GPS BILSTEIN HD SHOCKS GOODYEAR GATORBACK SERPENTINE BELT. HYPRO CAI KIT. MAG-HYTEK TRANSMISSION PAN MR GASKET RADIATOR CAP WITH BUILT IN THERMOMETER.
Old 10-15-2008, 12:16 AM
schusterjo's Avatar
schusterjo schusterjo is offline
Section Moderator
Dodge Forum Moderator
1999 Dodge Durango
Vehicle: 99 Durango 4X4 5.2L
CHAMPION Iridium.... Runs like a dream...
Old 10-15-2008, 07:47 AM
Durango03's Avatar
2003 Dodge Durango
Magic, Any other mods you have done? Whats yur avg/ MPG?
sterjo, I saw those are popular for this engine, I just saw these plugs on sale and had to ask. Any noticeable difference in the Iridium?
__________________
Sean
'03 Durango 4.7
'97 Avenger 2.5
'76 Cobra II 5.0
'78 Mustang II 2.3
Old 10-15-2008, 08:39 AM
schusterjo's Avatar
Section Moderator
1999 Dodge Durango
Well I have a 5.2L and yes I did notice a difference. Smooth idle and helped fuel mileage slightly..
Old 10-15-2008, 09:57 AM
hydrashocker's Avatar
hydrashocker hydrashocker is offline
Moderator of Mayhem
Vehicle: Custom Built 1998 Durango 5.9L
The Autolite plugs are a small step colder plug so I warn you that using them creates a different burn and therefore can create buildup.
I have seen people install them and trough a missfire usually on #7. I would incorage you to use OEM Champion Rugular plugs, Champion Truck Plugs, Or Champion Iriduim. Just depends on how much money you want to spend. I run the Champion Truck Plug before and after my MSD ignition and really like em. I replace my plugs every year or about 10k to 15k. I can usually feel the ignition and know when it's time. But make sure you replace the plugs (OEM) absolutly every 30k.
Iridium is running great so far. DO NOT USE PLATINUM! The motors were not set up for their use.
If I were you I'd take them back period! Get yourself some reg OEM plugs for a couple of dollars more. Don't forget to gap em!
__________________
Quote:
Originally Posted by rebelboy
bet your motor aint as big as your mouth is.
I don't take sides.....I hate everyone equally.
Old 10-15-2008, 11:29 AM
gr8scott72 gr8scott72 is offline
Autolites run great in the 5.9 but I don't know about the 4.7.
You can't beat an $8 spark plug change.
__________________
Scott
00 Durango SLT 5.9L 2wd, Fastman tranny, 4.56:1 gears, added leaf spring, Hawk Superduty pads ,Bilstein HD, Yoko Geolander H/T-S 265/75/15 ,Optima Red Top battery
Old 10-15-2008, 10:21 PM
MAGIC84's Avatar
2003 Dodge Durango
"Magic, Any other mods you have done? Whats yur avg/ MPG?"
I have squeaked out 18-20 MPG highway Cruise @ 70 A/C on Windows closed it takes a bit of work to get the cruise set for highway trim but you get used to it after a while. No other mods except for the XM radio. I am trying to get some input and funds for a K&N CAI kit and new exhaust like magnaflow or flowmaster. Long term projects include recovering the front seats and installing seat heaters, new headlights, taillights and r/r the cracked center console.
__________________
Old 10-16-2008, 01:37 PM
Moderator of Mayhem
If ya blow the motor like the last guy then have at those $8 plugs!
There has only been a hand full of people that liked them period.
__________________
Old 10-16-2008, 01:41 PM
Moderator of Mayhem
BTW<------They don't work in the 4.7L
__________________
Tags
47, 47l, 58, autolite, champian, champion, copper, dodge, durango, iridium, misfire, plug, plugs, socket, spark, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
