I have the Firestone Destination A/T's and we got 7+ inches of snow and ice today and I didnt slip ONCE doing 40-45. when coming to a stop apply little break let off and a little, etc.... Also downshifting helps.
This ad is not displayed to registered and logged-in members. Register your free account today and become a member on Dodge Forums!
__________________
Sean
'03 Durango 4.7
'97 Avenger 2.5
'76 Cobra II 5.0
'78 Mustang II 2.3
Sponsored Links
Registered users do not see this ad. Click here to register for free!
Speaking of down shifting if I have to stop sooner that expected I put it in neutral because the tranny still pushes while braking. Stops are way way shorter than normal when done in this manner.
__________________
275/45/20s+30X9.5's for the winter, Bilstiens, Moog ball joints, Personal made front grill, Custom made ram air, Tornado, Fuel Boss, Champion spark plugs, Accel ignition coil, new GMB water pump, 180 degree Jet T-stat,rebuilt trans with shift kit, PVC enhancer!
The ABS under 10 MPH disengages the rear wheels under light brake stopping.
Basically, the rear wheels have the opportunity to still turn. Now the older versions allowed even more power to go to the rear wheels but they did do a better job with the D.
Now I haven't had as much problems with this because I fixed a OEM failure on the brake shoes and the rear wheels stop as normal. I just don't know if this is a on going problem or if they did do mostly away with this problem?????????
I like to slide too bo!! it makes things things fun
__________________
i have those tires to i broke my transfer case so i no longer have 4x4 but i havent been stuck yet i live on longisland so the deepest snow weve gotten was about 4 inches in the last few years but the ice is serious i love the tires and highly recommend them
Dro you should just add that smiley to your sig. It would save you time.
Downshifting is a huge help when trying to slow down.
Maybe in time... I was told by a friend to add smiles so people don't think I'm being mean...Green
BTW thanks for trying
__________________
Sounds great I like taking shots back at smart mouthed dummies
__________________
