Last edit by: IB Advertising
Browse all: 4WD
- Dodge Ram 2nd Gen How to Transfer Case Motor
Step by step instructions for the do-it-yourself repairs.
Browse all: 4WD
Transfer Case Control Module Location, TCCM
#141
#142
2002 Dodge Dakota 4.7 Quad cab
Thanks to everyone for the great information. I appreciate all the work you have put into this forum. I just replaced my TCCM. (bloody knuckles) and no change in my no switch light no 4x4 condition. I am now going to chase electrical shorts. I will post back when I can get her up on a lift.
TCCM replaced, no fix yet.
#143
#144
I had all the symptoms that pointed to a TCCM issue, I tried two different TCCM's from scrap yards and it didn't help.
I also had a mechanic look at it while checking out some other things....the mechanic didn't have the proper Chrysler tool, but he said they ruled out about everything BUT the central timing module, which I guess is the body control module mentioned in the post above because it's in the driver side kick pane. I didn't do anything wtih that info yet though because I heard it needed to be done at the stealership...
Question, does a dealership need to replace the body control module??? I heard it needed to be flashed with a VIN or something....thanks for any feedback.
Mine is a 2003 Dodge Durango 4.7L SXT with non functioning 4x4
#147
#148
Tccm
I have a 2003 dodge Dakota 4.7 4WD my 4 wheel drive does not work I put it on a scanner it said I had a internal error so I went on alldata and it said it was my transfer case control module and to check all my connections and I did they where good then I got a used one and it said the same internal error I went to my home town dodge dealer and they said the vin is programed in to that truck so do you have to buy a new one will a used one work
