P0340 & P1391 Error Codes, no start sometimes
Old 03-07-2009, 03:32 PM
hydrashocker's Avatar
hydrashocker
hydrashocker is offline
I didn't know the was 2 different ones. Thats one reason that I dislike Kragen's. Every time I go there I get the wrong part. I think their part systems are crap.
I prefer Auto Zone or the dealer for parts.
Old 03-26-2009, 06:01 AM
beave's Avatar
beave
beave is offline
Well its been 3 weeks now and no problems at all. I'd say that was definitely the problem.
Beave
Old 07-03-2009, 05:20 PM
DurangoRT/RN's Avatar
DurangoRT/RN
DurangoRT/RN is offline
I just posted this problem...
Off to go buy this part and try it out!
I love this site...
Old 09-12-2014, 09:03 PM
BTS's Avatar
BTS
BTS is offline
Default P0340 5.9 engine
I have similar problem. Engine does not stall but when at full running temp engine intermittently will not restart when shut off. At this time is when I get the code. The problem is happening more and more frequently. I have a ODBII tester and clearing code rarely helps it start. I have also noticed that It tries to fire for a second just as key is turned, then it seen turnover without resistance. It always starts after full cool down with or without code cleared.
I am going to try distributor pickup (Sensor) as first try.
I have question about the variant tolerance in PCM for cam to crack position. My vehicle has 190K + miles and expect that slop in timing chain could push variant past tolerance for PCM. This may explain why it always starts in the PCM's close loop mode.
Old 09-12-2014, 09:15 PM
dxloat's Avatar
dxloat
dxloat is offline
I had the same problem, turned out to be the crank sensor between the firewall and bell housing. When it got hot an internal wire in the sensor must have lost continuity due to the expansion after heating up, replaced it and things were back to normal.
Old 04-21-2015, 03:42 PM
james101abn's Avatar
james101abn
james101abn is offline
I am having the same problem from my 97 ram. Threw a p0340 code replaced both sensors and it still won't start just cranks...
Old 04-28-2016, 12:06 AM
Joshua Vansyckle's Avatar
Joshua Vansyckle
Joshua Vansyckle is offline
Default Try to replace ignition coil it sounds like your not getting enough fire to the plugs
try replacing the ignition coil your not getting enough fire to the plugs
Old 04-29-2016, 05:45 PM
Joshua Vansyckle
That's how my 99 dodge 1500 mag acted as well I changed the ignition coil and it started but now its throwing a code p1391
Old 04-02-2018, 03:07 PM
Shawn Prince's Avatar
Shawn Prince
Shawn Prince is offline
Default Different sensor connections
So I recently put a motor from an automatic into my 98 1500 with manual transmission. During the swap I noticed almost all the sensor connections were different between the two harnesses. Why dodge decided to make them different between the manual and auto is beyond me. I ran into the same issue with the cam position sensor. The black one is for and auto and the grey one is for the manual
Old 07-12-2018, 03:21 PM
yankee1957's Avatar
yankee1957
yankee1957 is offline
Default 2002 dodge 1500 motor swap pulling hair out
Just put a used 4.7 in dodge 1500 pulled from 2002 durango both seem same had durango running before pulling. original 1500 motor was cooked. Got p1391 and 340 codes does the computer have to relearn or flashed for engine swap. Ive got new sensors coming crank and cam . It acts like it wants to fire checked cam sensor got 5 ohms
Quick Reply: P0340 & P1391 Error Codes, no start sometimes
