DodgeForum.com
DodgeForum.com Home - Dodge Marketplace - Dodge Photo Galleries - Create an Account - Dodge News
Go Back   DodgeForum.com > Dodge SUVs > Dodge Durango > 1st Gen Durango
Thread Tools Search this Thread
Old 04-06-2009, 07:39 PM
hydrashocker's Avatar
hydrashocker hydrashocker is offline
Moderator of Mayhem
Dodge Forum Moderator
Vehicle: Custom Built 1998 Durango 5.9L
The filter is on the down side of the temp sensor and heads..... Check that first!
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on Dodge Forums!
__________________
Quote:
Originally Posted by rebelboy
bet your motor aint as big as your mouth is.
I don't take sides.....I hate everyone equally.
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
Old 04-07-2009, 10:21 PM
teck78 teck78 is offline
1999 Dodge Durango
My Garage
Vehicle: 05 F150 FX4
Unhappy 5.9 no oil pressure
The Durango was driving fine......but, every once in awhile i would get the check gauges alert because the oil pressure reading zero. thought it was the sending unit. Had no other issues. Then the Durango sat over night. started it in the AM had the check gauges alert because of the oil pressure drove it maybe 4 blocks then i got a lifter tick. So then i knew it was not just the sending unit. So what are the odds of the oil pump going bad? I thought these 5.9 liters where like the salt of the earth like the 302, 350, 318,.....what would cause this issue. i have heard that sludge is a issue with these. please someone in the know....give a hand. The oil pressure is zero....with a mechanical guage. what should i try next before i give it to the .....$$$shop$$$$.
Thanks T
Old 04-07-2009, 11:17 PM
IndyDurango's Avatar
IndyDurango IndyDurango is offline
Vehicle: 2000 Demon Durango SLT+
5.9s are rock solid if you take care of them. Doesn't mean an oil pump can't fail. Usual suspect? No. Possible? Sure.
I was thinking maybe your oil gauge was failing (happens) but that wouldn't cause a lifter tick. That's an oil pressure drop.
Sludge is a falsehood. No issues with sludge on the 5.x UNLESS you mix every different kind of oil and standardize on no brand or weight each and every fill. Do that and you are on your own regardless of the motor or brand.
IndyDurango
__________________
- Truck of the Month: 12/06 DodgeForum.com, 1/06 DurangoClub.com, 07/07 Dakota-Durango.com
- Durangoer of the Year: 2006 DurangoClub.com
Old 04-07-2009, 11:54 PM
DRO318's Avatar
DRO318 DRO318 is offline
2000 Dodge Durango
Vehicle: 2000 Dodge Durango 5.2 mag
did you ever try changing the filter like hydra said
__________________
275/45/20s+30X9.5's for the winter, Bilstiens, Moog ball joints, Personal made front grill, Custom made ram air, Tornado, Fuel Boss, Champion spark plugs, Accel ignition coil, new GMB water pump, 180 degree Jet T-stat, rebuilt trans with shift kit, PVC enhancer!
Old 04-08-2009, 12:01 AM
1999 Dodge Durango
My Garage
Question With no oil pressure
So what would be the usual suspects for a no oil pressure issue...would a oil pump fail every once in awhile then just go. I was thinking maybe sludge because it came and went. i had no other issues it was running fine...then it just came like before (no oil pressure and check guages alert) and has not gone away.
Old 04-08-2009, 12:41 AM
Moderator of Mayhem
LESSON!
Check the filter. Do a oil change with 10W-40 and change the filter. If the problem is a weak spring on the oi pump or a warn impeller it can do this. I sometimes have issues when exessive heat from pulling on the oil liquifies the oil too much to pick up. Also it can do that if you are runnin low.
__________________
Old 04-08-2009, 01:56 AM
If you are set on swapping the oil pump, please show us your milage on the odo and the non-sludge photos you will find in there. It would be valuable and appreciated in regards to future 'sludge' rebuttals.
TIA,
IndyD
__________________
Old 04-08-2009, 03:02 AM
1999 Dodge Durango
My Garage
Question how does
Say that the oil pump is good where would the oil get blocked to the point where it would not flow up to the lifters? in a step by step how does it go from the pump to the head/lifters? Is there ONE thing that could stop the oil from reaching the lifters other than the oil pump? i will do the oil/filter change and let you know...how it goes. thanks for the input.
T
Old 04-08-2009, 09:52 AM
DRO318's Avatar
2000 Dodge Durango
For your sake I hope you find it is the oil filter. If it is, we all know that's a cheap fix
Other wise I don't see anything else that could be the prob if you kept up with the maintenance and didn't use cheap oils and filters
__________________
Old 04-08-2009, 04:37 PM
Moderator of Mayhem
THERE IS NO SLUDGE ISSUES HERE!
If you or the previous owner used crappy lubricants or maintenance scheduals then you get whats coming. There is no sludge issues.
Now you want to know whats in line before the heads and sensor........ Check the filter!
__________________
Tags
52, durango, lifter, tick, ticks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
