Yes, def. change the plugs to Champion Truck or Iridium. I would also ATLEAST drop a K&N filter in place of your OEM. Make sure your tire pressure is accurate as well. I would make the switch to Synthetic oil if you havent already.
Just for reference, I just took a 3 hour trip and ran No Les than 85 MPH and got @ 400 miles on 1 tank... I think it averaged out to be @ 18-19 mpg. I thought that was good for as fast as I was going.
This ad is not displayed to registered and logged-in members. Register your free account today and become a member on Dodge Forums!
__________________
Sean
'03 Durango 4.7
'97 Avenger 2.5
'76 Cobra II 5.0
'78 Mustang II 2.3
Sponsored Links
Registered users do not see this ad. Click here to register for free!
I have an 04 Durango - bought it used two months ago with 33,000 miles on it. I have been averaging 12 mpg each and every week driving back and forth to work (7 miles each way with several traffic lights) and on short trips during week-ends. Then last week, I drove to VA and back to MA on Route 95 and was pleased to average 20 to 21 miles per gallon!
After returning home, I changed from petroleum oil to Mobil 1 synthetic and I ordered a K&N air filter drop-in replacement. I'm hoping to increase from 12 mpg to 14 but I'll let you know when I fill-up again.
Again, I will check with the actual fill up, but so far I am picking up about 20-25 miles per tank. From about 290, now indicating about 310-315. I got about another two-three days before fill up again, but early results look good. I know it may be some other factors but since I haven't made any dramatic changes in my driving habits I am going to give a good bit of credit to the new Bilstein's. I am still in the market for a CAI but I would say that good riding shocks are a good player in fuel economy.
__________________
2003 DURANGO SLT 4X4 4.7 3RD ROW LEATHER SONY XM/SIRIUS STEREO MICHELIN X-RAD LT BOSCH WATER PUMP DURALAST C-MAX BRAKES DURALAST ROTORS MAGELLAN MAESTRO GPS BILSTEIN HD SHOCKS GOODYEAR GATORBACK SERPENTINE BELT. HYPRO CAI KIT. MAG-HYTEK TRANSMISSION PAN MR GASKET RADIATOR CAP WITH BUILT IN THERMOMETER.
I didn't say anything last mention because I though I had read it wrong... however now with the statement coming up twice... I must say you are the first person I can ever recall giving kudos to new shocks for any mileage gains much less the big gains you are seeing.
My money is on better fuel with the spring blends/summer blends/winter blends, etc WAY MORE so than on any set of shocks.
JMHO!
IndyDurango
__________________
- Truck of the Month: 12/06 DodgeForum.com, 1/06 DurangoClub.com, 07/07 Dakota-Durango.com
- Durangoer of the Year: 2006 DurangoClub.com
JMHO!
IndyDurango
yea thats what i would blame it on too, but again jmho
I meant 20-25 MORE miles per tank, so up from 290 to 310-315. I did the fill up today. mileage/range did go up, not quite as much as originally indicated, but still up. Last was 17.0 gals/255 miles so about 15 MPG. This tank was 18.0 gals/300 miles, so just a touch over 16.5 MPG and 45 miles over last tank. I am reasonably happy, and I still credit a portion of it to the new shocks. This was actual fill up mileage not overhead computer mileage.
I had not given to the change to summer blends, and that makes sense. I figured all the summer blends would be out "on the streets" (no pun intended) by now.
I think even though I went up, there is not a lot you can expect from stop/go driving but I am thankful for all the input from the members. I am reasonably satisfied with the improvements however little they are that the shocks provided. With the ride and handling improvement I would be satisfied even if there was no MPG improvement. I say we chalk it up to a combination of events, summer blend fuel and shocks. I will still try the Champion Truck plugs and when financially able a CAI, and exhaust system.
Thanks,
Steve
__________________
