DodgeForum.com
DodgeForum.com Home - Dodge Marketplace - Dodge Photo Galleries - Create an Account - Dodge News
Go Back   DodgeForum.com > Dodge SUVs > Dodge Durango > 1st Gen Durango
Thread Tools Search this Thread
Old 05-09-2009, 06:07 PM
IndyDurango's Avatar
IndyDurango IndyDurango is offline
Vehicle: 2000 Demon Durango SLT+
There is and it is on the 4.7s only. The PCV gets a 'snot' buildup due to air and moisture. Unknowingly, many think THAT is sludge. Isn't.
How many top ends off have you seen pictured on 5.xs or 4.7s? Intake replacement photos? Valve cover replacement photos? Ever see sludge? Nope.
IndyD
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on Dodge Forums!
__________________
- Truck of the Month: 12/06 DodgeForum.com, 1/06 DurangoClub.com, 07/07 Dakota-Durango.com
- Durangoer of the Year: 2006 DurangoClub.com
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
Old 05-10-2009, 03:48 PM
hydrashocker's Avatar
hydrashocker hydrashocker is online now
Moderator of Mayhem
Dodge Forum Moderator
Vehicle: Custom Built 1998 Durango 5.9L
Quote:
Originally Posted by IndyDurango View Post
There is and it is on the 4.7s only. The PCV gets a 'snot' buildup due to air and moisture. Unknowingly, many thing THAT is sludge. Isn't.
IndyD
Slow down Indy.... Never said it was a sluge.
Quote:
Originally Posted by hydrashocker View Post
Speaking of this, does anyone remember the moisture TSB on the crank case vent = brown oil film? I thought there was a TSB but can't remember on the 4.7L?
I ment that this particular thing was off topic and said it was a moisture issue. This has nothing to do with sluge. Fact is that the issue caused brown build up and could result in inaccurate lubricant levels. I looked into it but couldn't find it. Do you know where it is?
__________________
Quote:
Originally Posted by rebelboy
bet your motor aint as big as your mouth is.
I don't take sides.....I hate everyone equally.
Old 05-10-2009, 04:47 PM
shrpshtr325's Avatar
shrpshtr325 shrpshtr325 is offline
THE ULTI-MOD
2002 Dodge Durango
My Garage
Vehicle: 2002 Durango
Send a message via AIM to shrpshtr325 Send a message via MSN to shrpshtr325
idk about the pcv getting it, but i occasionally get (in the winter) a build up of like yellowish/white stuff in the filler neck, just the same "snot" type stuff you are talking about and from the moisture, as long as it gets cleaned out before the new oil is poured in at change time its not an issue IMO,
__________________
http://dodgeforum.com/forum/groups/bike-fun.html
REAR WIPER CLUB MEMBER #2
Quote:
altair - I need something that lets me stab people in the face over the internet
User2006:i have better things to do like... work on my truck and masturbate.
big.bryant: damn dude thats pretty rough... i would hate to be his girlfriend lol
wink2873: i would tell my girlfriend i want her to be a little bit quiter.
Old 05-11-2009, 12:06 AM
Moderator of Mayhem
But I thought that was an issue with the crank case vent and not the PVC. Does anyone know the years and the TSB for this?
__________________
Old 05-11-2009, 12:41 AM
All Gen1 4.7s
Service Bulletin Number: 090100A
CUSTOMER MAY COMPLAIN OF AN OIL EMULSION ACCUMULATION INSIDE THE ENGINE OIL FILL HOUSING
Need to install the following 2 parts
53032126AA Baffle, Oil Fill Housing ($1.20)
53032389AD Cap, Oil Fill Housing ($5.10)
Also replace the PCV valve as well. Here is more detail:
Quote:
Originally Posted by tomk
More detail:
The PCV valve is up in the filler neck (instead of the valve cover where it's on a lof of other engines). When it's doing it's job, the PCV system sucks vapors out of the crankcase to be run back through the intake and burned. These vapors are warm, but the filler neck is (relatively) cold… so the vapors tend to condense on the inner surfaces.
The new filler neck has a removeable baffle that mostly keeps the bulk of the vapors out of the part of the filler neck that you can see… and I *think* the filler cap is modified to have a bit of an insulating air space…
This topic often pops up when cold weather sets in, because the filler is that much colder and thus more likely to have condensation…
Here is the neck with all the snot... NOT sludge.
and
If my 5.9L had a snot issue, I'd die! OMG!
Indy(not a 4.7 expert)Durango
__________________
Old 05-11-2009, 07:16 AM
MAGIC84's Avatar
MAGIC84 MAGIC84 is offline
2003 Dodge Durango
Vehicle: 03 DURANGO SLT
The above photos show what appear to be a extreme example, but here is the conditions when I observed it the most.
Cold dry weather, early morning in the winter. I had about a seven minute drive from home to work for two winters in a row. It was just enough for the engine to get semi warm and the condensation to accumulate in the baffle. I will not speak for everyone but those two winters, here was my solution. I purchased the vehicle in DEC06. ran the minor "SNOT" for the winter and had a oil change around the end of MAR 07. Ran summer with no problems then around OCT 07 I had another oil change. Winter of 07 had minor "SNOT", and again April 08 had another oil change. Oil change cleaned out the condensation. Last winter my ride to work was about 15-20 minutes so the engine had more time to warm up and burn off the condensation. Basically it is a plastic oil neck and the metal of the engine and not a whole lot that can be done. Yes it was a poor design by Chrysler but I guess there is no sense crying over spilled milk now. During the winter months I monitored the oil cap, and cleaned what I could, even removing the baffle and wiping off the condensation as necessary This winter I had no issues with the condensation so I am figuring it is a problem with short runs when the engine gets warm enough to pool the condensation but not warm enough to burn it off. Again once my commute turned longer there was no condensation after this winter.
Obviously oil and water dont mix well, but at least in my case, it was a minor issue, and it appears that most of the snot was contained in the filler neck portion, and not circulated throughout the whole system. If you know what conditions exist for the presence of the "SNOT" and monitor, inspect and clean the filler neck, baffle and cap as necesssary and perform a oil change at the end of winter, I wouldnt see any major issues. Short of a class action lawsuit for Chrysler, which they need like a hole in the head right now, I don't think there is much you can do. It sounds like from previous threads that the baffle helped a lot but still there is a certain amount of monitoring that the driver should comply with.
Hope this helps.
Steve
__________________
2003 DURANGO SLT 4X4 4.7 3RD ROW LEATHER SONY XM/SIRIUS STEREO MICHELIN X-RAD LT BOSCH WATER PUMP DURALAST C-MAX BRAKES DURALAST ROTORS MAGELLAN MAESTRO GPS BILSTEIN HD SHOCKS GOODYEAR GATORBACK SERPENTINE BELT. HYPRO CAI KIT. MAG-HYTEK TRANSMISSION PAN MR GASKET RADIATOR CAP WITH BUILT IN THERMOMETER.
Old 05-11-2009, 04:53 PM
Moderator of Mayhem
I thought the was a 4.7L TSB for this issue but i couln't find it. Thanks for the post Indy!
Even with the snot that it can make there isn't enough made to show a incorrect lubricant level like i stated earlier. In those pic's your showing there is maybe only a couple of TSP of lubricant at the most could be involved. It would take a lot more than that to give inaccurate level on the dip stick.
__________________
Old 05-12-2009, 05:11 AM
MetalDrgn's Avatar
MetalDrgn MetalDrgn is offline
Vehicle: 85 camaro, 98/02 Durango
well I ended up driving back to buy it. I also talked him down to $2000. Now that I own it, I can say it was off craigslist in atlanta. it's a black SLT with power everything and leather (mmmmm).
I'm going to post a seperate post, but I need to know if I can tow a durango with a durango. the towing capacity is like 400lbs less than the weight of the vehicle which could be a problem, but can I add the max load to the tow rating?
Old 05-12-2009, 01:45 PM
Kensai's Avatar
Kensai Kensai is offline
Vehicle: 2000 Black Durango R/T
MetalDrgn,
We have a thread here concerning towing limits on the D. Indy posted up a good accurate rating on various configuration between 2wd/4wd and the 4.7-5.2/5.9 engine and tranny.
__________________
Black 2000 Durango 5.9 R/T, Infinity Reference 6012i, Clear Headlight lens,
Fastman 52mm ThrottleBody,Fastman custom built Tranny,Castrol Full Syntec,
OEM K&N Air filter,Monroe Reflexes,BFG LongTrail Touring T/A's,180 Stat,
Champion IR Truck Plugs,Hypertech III (87 oct),Custom Made Ram Air Intake,
Old 05-12-2009, 06:52 PM
MetalDrgn's Avatar
have a link? I can't find it
Tags
47, 47l, condensation, covers, crankcase, dodge, durango, engine, failure, knock, magnum, removing, startup, tick, v8, valve
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
