DodgeForum.com
DodgeForum.com Home - Dodge Marketplace - Dodge Photo Galleries - Create an Account - Dodge News
Go Back   DodgeForum.com > Dodge SUVs > Dodge Durango > 1st Gen Durango
Thread Tools Search this Thread
  #61
Old 07-11-2009, 01:11 AM
MetalDrgn's Avatar
MetalDrgn MetalDrgn is offline
Vehicle: 85 camaro, 98/02 Durango
The plastigage is wrong. period. it's out of the range.
Again, I measured .0266" smaller than the smallest stock size journal limit. They sell undersize bearings at .25mm(.01"), .5mm(.02"), and .75mm(.03"). The .75mm would overlap the journal by .003" so that can't be used. The .5mm US would make it .0069" clearance which is more than 3 times over the largest specified gap (.0022").
Even if a .75mm US bearing would work, I would just replace the crank becuase that means the journal, even though it appears good, had a lot of metal ground off by the spun bearing making it unreliable. I don't have an rA meter and I don't have a micrometer to check for taper and out of round and other critical things as such. So instead of risking another spun bearing, I'm going to just pull the engine and replace the crank and all the bearings.
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on Dodge Forums!
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
  #62
Old 07-11-2009, 04:13 PM
hydrashocker's Avatar
hydrashocker hydrashocker is offline
Moderator of Mayhem
Dodge Forum Moderator
Vehicle: Custom Built 1998 Durango 5.9L
I think that's the best decision yet!
Pull that basterd out and build it nice:
Look in here for great ideas:
Longevity & Power Of Your Rig!
__________________
Quote:
Originally Posted by rebelboy
bet your motor aint as big as your mouth is.
I don't take sides.....I hate everyone equally.
  #63
Old 09-14-2009, 05:54 AM
MetalDrgn's Avatar
Talking
Well I finished the engine rebuild a few weeks ago, but the engine was smoking real bad from one of the cylinders (maybe more I don't know) and I was trying to see if I needed to rebuild it again and I was trying to isolate it. Not to mention I bought a 98 Expedition and did a little work on that too along with so many other things. I was so close to calling the rebuild a failure, but I just couldn't give up so quick. I kept starting it and running it to see if I could figure out what cylinder was leaking and why. I even disconnected each cylinders coil to try and find out which one it was. That didn't seem to help. I had added about half a quart of heavy duty oil stabilizer to see if it would help, but it didn't really seem to. This last weekend I decided I would drive it longer because it may just help seal the rings better. There was only about 2 miles on the engine so I had to see if it would get better so I went out and drove it down the road for a few miles. I could see the smoke behind me, but it was a lot less than when I first ran it. Just after about 7 miles, it was hardly leaking!
Now it doesn't smoke at all!!!! It kept getting better and better until it doesn't smoke at all anymore! I'm so grateful it worked. If I would have had to rebuild it again it would have been over $1200 plus a lot of time and time I am in short supply of atm. It also proves it is possible to reuse rings and still have a good seal even after 136k miles. I imagine I'm going to get about 40k-50k miles before I need to rebuild it again, but that's a few years down the road. My timing chain guides are getting close to their wear tolerance, but shouldn't be due for another 35k-40k miles so I'm good for now. The transmission shift quick and very nice too so this one may last quite a while! There are a few other problems with it, but they are minor and will be fixed shortly.
  #64
Old 09-14-2009, 09:44 AM
x99j x99j is offline
Vehicle: 2006 dakota 3.7 manual trans
great news1 i have been following this since you bought it.
  #65
Old 09-22-2009, 11:01 PM
MetalDrgn's Avatar
thanks! I'm so glad it worked. Now I just have some minor stuff to fix like the window regulator and a few other things.
Tags
47, 47l, condensation, covers, crankcase, dodge, durango, engine, failure, knock, magnum, removing, startup, tick, v8, valve
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
