DodgeForum.com
DodgeForum.com Home - Dodge Marketplace - Dodge Photo Galleries - Create an Account - Dodge News
Go Back   DodgeForum.com > Dodge SUVs > Dodge Durango > 1st Gen Durango
Thread Tools Search this Thread
Old 05-25-2009, 02:20 AM
Neo1130 Neo1130 is offline
Vehicle: '99 Durango SLT 5.2 4x4
Default Random high idle
Getting a problem the past week now. I am getting a random high idle, anywhere from 1,000 RPM to 2,000 RPM... Normal idle is around 700. Happens mostly when coming to a stop and I have to mash the brakes a little harder than normal. When I stop the idle is around 1,200 and when I put it into neutral or park, it will shoot up to 2,000 and stay there.... I tried to pull the throttle back and tap it but it stays there... Happens maybe 15 seconds each time. Would the idle control valve cause it to go this high? Also, where is the MAP sensor located?
Oh yeah, TPS is new and there are no vacuum leaks...
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on Dodge Forums!
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
Old 05-25-2009, 02:34 AM
IndyDurango's Avatar
IndyDurango IndyDurango is offline
Vehicle: 2000 Demon Durango SLT+
TPS.
Also check the Vac lines under the hood. I hear propane is a good method.
IndyD
__________________
- Truck of the Month: 12/06 DodgeForum.com, 1/06 DurangoClub.com, 07/07 Dakota-Durango.com
- Durangoer of the Year: 2006 DurangoClub.com
Old 05-25-2009, 02:35 AM
TPS is new... Tried propane... No leaks as stated in original post...
Old 05-25-2009, 04:39 PM
hydrashocker's Avatar
hydrashocker hydrashocker is offline
Moderator of Mayhem
Dodge Forum Moderator
Vehicle: 1999 Ram 2500 V-10 QC 4X4
If you put your info in the Your Profile or in your signature Edit Signature that includes your vehical year and engine size it really helps us in giving you the right info. If you look at my posts I have my info on my rig in both the top right and also in my signature.
Your throttle cable could be sticky, or the throttle body plate could be sticky. Vacuum wouldn't go that high in my opinion. IAC could need cleaned. TPS out.
__________________
I don't take sides.....I hate everyone equally.
Old 05-25-2009, 08:56 PM
Your edited post was within minutes of my reply. Must not have been in there when I originally read it. I could have missed it. Nothing stated about Propane.
Dunno. You'll figure it out. Good luck.
IndyD
__________________
Tags
1998, 2000, 2500, caravan, dakota, dodge, durango, high, idle, idles, jeep, park, ram, random, stop, van
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
Vendor Directory
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
