I was originally going to say MESH but after that story of Kensai and the snow, it got me a little freaked. I am moving to Minneapolis and will expect snow and cold there. Cosmetically I like the mesh, but for function I might have to go with the billet, and horizontal. I do like the black or maybe painted frame though. Tommy, what about mesh but take the Le-Bra off for the winter?
__________________
2003 DURANGO SLT 4X4 4.7 3RD ROW LEATHER SONY XM/SIRIUS STEREO MICHELIN X-RAD LT BOSCH WATER PUMP DURALAST C-MAX BRAKES DURALAST ROTORS MAGELLAN MAESTRO GPS BILSTEIN HD SHOCKS GOODYEAR GATORBACK SERPENTINE BELT. HYPRO CAI KIT. MAG-HYTEK TRANSMISSION PAN MR GASKET RADIATOR CAP WITH BUILT IN THERMOMETER.
You should go with the original OEM bra if they still sell them. The only difference is the OEm bra does not mesh, but does have the cut outs for fog lights.
I think Lebra, you can buy one without the mesh. Then you can purchase a mesh to fit behind the grille and is easily removable to clean or not use in terms when you are going thru heavy snow storms.
Hey, maybe you can find a mesh that has something like background heating to keep snow/ice from building up on the mesh? haha Kinda same function as our side mirrors that are heated to prevent ice buildup.
__________________
Black 2000 Durango 5.9 R/T, Infinity Reference 6012i, Clear Headlight lens,
Fastman 52mm ThrottleBody,Fastman custom built Tranny,Castrol Full Syntec,
OEM K&N Air filter,Monroe Reflexes,BFG LongTrail Touring T/A's,180 Stat,
Champion IR Truck Plugs,Hypertech III (87 oct),Custom Made Ram Air Intake,
Thats the ultimate look right there...... Don't let that go to your head Indy!
Thank you my friend!
IndyDurango
__________________
- Truck of the Month: 12/06 DodgeForum.com, 1/06 DurangoClub.com, 07/07 Dakota-Durango.com
- Durangoer of the Year: 2006 DurangoClub.com
I've seen that and done right it isn't bad. Unless you tell someone, they wouldn't even know.
Using Gutter Guard and making your own inserts is also an option used often.
IndyD
__________________
IndyD
yup there is even a write up for it in the 2nd gen dakota section if your interested, i have thought about doing that one, but havnt gotten around to it
