Wheel bearing
+1 on not buying used hub/bearing assemblys.
Here is a website $128 for the Rear ABS and $194 for 4wheel ABS
http://www.autopartswarehouse.com/se...294963295+7029
Good luck!!
Steve
Good luck!!
Steve
Trending Topics
This link confirms the application: http://www.autozone.com/autozone/cat...entId=cat30059
but, buy it from Rockauto. $55.79
1. Remove snap ring.
2. Press out old bearing.
3. Lube bearing OD and hub ID. Press in new bearing. Make sure you press only on the outer edge of the bearing.
4. Replace snap ring.
BTW, I have one in my hand thanks to my dad, so I know it fits.
